Question about US Logic DVD800P Portable DVD Player
Trying to find a particular ribbon cable P-TWO AWM 20696 E221612
The cable is for a Dell Monitor going between the display and the logic board. I was replacing the power inverter board and while disconnecting the ribbon cable, it ripped a little. I have been trying to locate a cable or figure out how to fix it?
Which model of Inverter Board does HP pavilion f1503 uses? My backlight keeps on dimming after 10 secs of start up. please be spefic with the model number
The part is a "ribbon cable" for an lcd monitor...ribbon made by Youngshin (AWM 2896 30V 80C VW-1).
2 ribbon cables for a hp pavilion f1503 LCD monitor (the two from the AD board to the TCP)
The LCD panel is made by HannStar (HSD150SX84).
Also, looking for other LCD parts, particularly:
the AD board for a Proview Pro-576 (I assume Sylvania PL-576 & Mag LT576s are similar); Board #: 200-100-AS576 Rev: B MV5-S2?
It uses a sampo inverter (QPWBGL8621DG) & a AU Optronics M150XN05 LCD.
Jun 20, 2012 | HP Pavilion F1503 15" LCD Flat Panel...
My monitor getting white when i turned on the system....and every thing is not visible.....please tell me the solution
If you get white glowing screen like the example in my troubleshooting guide, then you need to check the ribbon cable between the logic board and the LCD panel's T-CON board, it can be that the fuse is blown on the T-CON board or the logic board is not sending the 5 or 12vdc to the T-CON board. You need to do visual inpsection for bad connections, caps, etc.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Sep 28, 2010 | Dell E198FP LCD Monitor
Screen goes white
Check the ribbon cable between the LCD panel T-CON board and the logic board. When you lose 5vdc feeding the LCD T-CON board the screen will glow white.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 31, 2010 | Dell E176FP 17" LCD Monitor
Monitor is displaying yellow or blue horizontal lines
You may have failing LCD controller (part of the LCD panel). Please verify first to make sure it is not PC video card problem by trying this monitor with other PC first. If it is the monitor, you can open it up and look for bad connection on the cable between the logic board and the LCD panel, etc,.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Apr 19, 2010 | Dell E173FP 17" LCD Monitor
Screen not displaying appropriate display at start up
Vetical line is the sign of failing LCD controller (t-con) board, which is part of the LCD panel assembly, it will get worst with more lines. You can try looking at the ribbon cable that is attached to the LCD panel and the Logic board to see it is not seated properly. You can look at what the connection looks like here:
You may also look for bad caps in the logic board and power supply board also.
Apr 07, 2010 | BenQ FP202W Monitor
Ribbon Cable on Necvox RE-9269D broke need replacement
You can go check at RadioShack or order the ribbon cable from EBay - http://cgi.ebay.com/HP-DV6000-DV9000-E220709-E118077-Power-Ribbon-Cable-/300393384553?pt=LH_DefaultDomain_0&hash=item45f0d74a69#ht_500wt_951
Oct 09, 2009 | Necvox RE-8169D 8 All-In-One Motorized...
How to disassemble monitor Dell 1800fp ?
Remove the base by the button release or 4 screws on the back. On the bottom of the monitor near the corners you will find two thin slots where you can insert a thin wide blade screwdriver or pry tool. Very gently pry the back from the bezel toward the center from both of these slots until the bottom is seperated, then contilue from the slots around the corners and up the sides until you have seperated the entire back from the bezel. Lay the monitor on the bezel and remove the back ( do not try to remove the bezel, at least not yet). Lift the tape that secures the ribbon cable from the bezel buttons to the logic board. Unplug the ribbon cable from the logic board by pulling on the connector (not the cable). Remove the cable covers from the back of the case (one has a screw, the other has a lift tab) and disconnect the lamp connectors and ribbon cable connectors (do not pull on the wires). remove four screws and lift the metal back from the screen.
May 15, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Flat Cable (P-Two AWM 20969 E221612)
you need to be patient because if you cant get it from the dell stores and still you can get it online you will need to visit a computer hardware vendor/ repairer who have thesame monitor but the monitor is completely damaged so that he can repalce it for you. but it is going to be expensive.
Dec 16, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
I am trying to repair or buy a P-TWO AWM 20696 E221612 cable
you will have to order the required cable here
http://www.globalsources.com/manufacturers/LCD-Computer-Monitor.html
check out this link
if this link do not help then check out for this another link
http://sagacious-tech.com.cn/products.asp?gclid=CJnNjLbTxZcCFckrpAodfySWSw
u will have to contact them if the cable is not mentioned and they will get it for u and provide you.also u can send mail if the contact numbers r not working
Contact
Tel:086-571-87804996 dot2.jpg Fax:086-571-87804033 dot2.jpg Email: sagacious@sagacious-tech.com dot2.jpg Email: nancy@sagacious-tech.com
US Logic DVD800P Portable DVD Player Logo
946 people viewed this question
Top US Logic Televison & Video Experts
Pavel Pranovich
Pavel Pranovich
jscuin6
Jesse Garza
Are you an US Logic Televison and Video Expert? Answer questions, earn points and help others
