Question about Elna 1010
ELNA 6005 Tension not correct
When I sew with my ELNA 6005 Heirloom Edition the stitch is OK on the top and loose below. I have set tensions, removed fluff, reset the computer, checked al the cottons tc and nothig wporks. I wonder if the tension has broken. Can anyone help?
SOURCE: satin stich scallops
stitch no. 29 "F "foot 7.0 width 0.4 length tension 2-3
Posted on Apr 11, 2008
Sewtech1
  • 69 Answers
SOURCE: Hi, my elna Super Su tension knob seems to be
bound to be some fluff stuck in between your tension plates of your tension unit
Posted on May 01, 2009
SOURCE: Elna 2007 making clicking noise - My elna is
it needs to be repair or traded in for a new machine
Posted on Nov 03, 2010
  • 1116 Answers
SOURCE: My Elna 6005 Heirloom
When you switch sewing modes, what does the display read as far as the stitch type you are using?
Posted on Aug 19, 2011
damneddle
  • 1607 Answers
SOURCE: Lost my users instruction manual
Hello
You can download it by going to this link:
Elna 6005
Once you get to that link, just rate by clicking the stars, then type anything on the "Give your opinion" box. Then click "Download User's Guide".
It is in PDF format, so if you can't open it, download and install Adobe Reader for free by going to this link:
Get Adobe
Posted on Sep 14, 2011
How to adjust bobbin tension on 6005 elna sewing machine?
Apparently this Elna model has automatic tension settings. May be something you need to have a professional technician address.
Feb 14, 2016 | Elna Heirloom Edition 6005
Tip
Heirloom 6005 won't do decorative stitches or zig.....
I found out the hard way. If your machine just refuses to do any zig zag or decorative stitches..check the Twin Needle Key. I replaced the mother board at a cost of $400 and then found out that was the problem.
on Mar 26, 2014 | Elna Heirloom Edition 6005
Elna 6005 - I need to move the tension dial to 9 to get an even stitch. I re-treaded the machine and bobbin and it is still the same. Any solutions?
it is common when threading a machine for the top thread to get behind the tension plates and not between them
this makes it bind up on the mount bolt and gives false tension settings
even threads also depend on the bottom thread tension which is adjustable by the tiny screw that holds the spring clip that you pass the thread under when you put the bobbin back in the case
try going google --type in-- workshop manual for elna 6005 --and see if there is a pdf version available,
Sep 06, 2015 | Elna Sewing Machines
My Elna 6005 turns on, but the mode buttons don't work at all. What can I do to fix it?
Check the "Twin Needle Button" It will interfere with decorative stitches.
Jan 10, 2013 | Elna Heirloom Edition 6005
How do I thread my machine? I cannot find my brochure. I sew a lot and have NEVER had this problem before--the stitches are all knotted at the back of the fabric. I dont know what I am doing wrong.
you need to check that the top thread is corrctly into the tension device, this is the most common cause of looping on the underside of the fabric because the tensioner is not pulling the top thread back up to the fabric surface as the needle is raised during the stitch sequence. Check that the tension is set to the middle number, usually 4 or 5, and that the thread has gone into the tension device. Always thread with the presser foot up, as this opens up the tension device so that the thread can seat fully.
Also double check that the bobbin thread is also fully into the tension spring and that the bobbin is in the right way, the thread needs to come off the spool and make a "V" shape as it reverses direction through the tension spring. If your bobbin is the same top and bottom, (ie plastic clear ones) it is easy to drop it in in the wrong direction. Some models have a little image on the clear bobbin cover showing right direction of rotation. Usually, when you pull thread, the bobbin will rotate counter clockwise (this is for horizontal top loading bobbins such as the modern Elnas).
If you can't find your manual then try this link to download a new one.
http://safemanuals.com search on Elna, then you should see a list of models over on the right including the 6005, click on it, then you'll get the option of giving your opinion, or using the security code to download. Click on the security code, watch the four digits that come up, and enter them into the other window alongside. You'll then get the download box. Wait for the pdf to load, its a large file.
Goodluck with your Elna.
Jul 14, 2011 | Elna Heirloom Edition 6005
Loose tension on bobbin thread
Using a scrap piece of material; try tightening the upper tension a bit at a time until the bobbin thread is smooth. Test stitch after each setting until you get the desired effect...happy stitching Gal.
Apr 11, 2010 | Elna Heirloom Edition 6005
There is a small metal 'thingamajig' that the bobbin thread goes by when it sew and every so often the plastic piece goes by that metal thing and cause loops on the underside. why is it doing this?
Be sure that your bobbin thread is correctly placed, is the correct thread for the fabric, usually the same as the top thread, the needle is correct size for fabric. Correct tension - balance your tension, use new needle for each project and correct pressure. Have the machine cleaned-lint build up. Use new thread, sometimes old thread breaks down and creates skip stitches.
Jul 19, 2009 | Elna Heirloom Edition 6005
Satin stich scallops
Jan 28, 2008 | Elna Heirloom Edition 6005
Sewing Machines Logo
98 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
