Question about GE Quiet-Aire Ductless Mini Split System Air Conditioner
R22 LOST (SOMEONE STOLE PIPE),
I have 2 ge minisplit, someone stole the piping, the r22 was lost. already have new pipe, hivac the line but do not know the amount of r22 psi?? I have not found the specs of my model ge ascd12db0 as0cd12db0 outdor unit as1cd12db0 indoor unit
  • katya sala Mar 25, 2007
    Manuals found...760grs is the amount of refrigerant needed for each minisplit.
Posted on Mar 25, 2007
    President:
  • 1,462 Answers
Be careful but dose in gas slowly until the frost line reaches the end of the evaporator
Posted on Mar 21, 2007
What is the quantity (gm/kg) of r 22 gas,that I can refill in panasonic 1.5 ton split ac?
There should be a label on the indoor or outdoor unit telling you the charge amount. You also have to consider the length of the pipe run which may need extra R22 added per meter after about 7m. But since R22 is being phased out world wide, it is usually extremely expensive and you're probably better off cutting your losses and installing a new one.
Oct 19, 2017 | Panasonic Heating & Cooling
My gree ac 2 hour running after ******* pipe is frosting . its gas pressure is 58psi and its have no dust.now what to do?plese ansure me!
If its R22 or R410A you will need to add the correct freon to the correct pressures. reduced air flow will cause low pressure readings also
Jun 20, 2016 | Heating & Cooling
How can i do engine timing on my honda luxline with a twincam engine of 1996
I have been a mechanic since 1947 and never known timing to affect the exhaust sound of an engine that would start and run with no other indications. perhaps someone stole the catalytic converter and put a straight pipe in its place.
Nov 28, 2014 | Honda Cars & Trucks
Phone lost wonder if someone is using it.
Where is my iPhone is the app that you want to use. You can access it at apples page. If it is not an iPhone you may be out of luck unless you installed a separate program to track it.
Oct 08, 2014 | Cell Phones
House a/c compressor runs for a while then shuts off
It could be going out on a high head pressure safety
Jul 04, 2014 | Ruud /rheem R22 /2 Ton/13 Seer Ac...
How much gass reqired in 1.5 ton ac r22
To many variables here to say. Pipe length, compressor size, acumulator, receiver etc. R22 very expensive here maybe not where you are.
Apr 20, 2013 | Fedders Appliance Air Conditioner...
R22 refrigerant charge how much on luxaire heat pump model LHJA18FS-AAA
hy mai name is tibi
solution is to upload up of 4.2 bar on thick pipe (gas pipe)
but you have to make sure the condenser is clean
good luck
Mar 07, 2013 | Heating & Cooling
How to hookup refrigerent gauges to central air?
Outside in the condensing unit you'll see the two copper pipes coming from the valves in the condensing unit. atach the hose from the high pressure gauge to the port in the smaller copper pipe (liquid line) and the other hose to the port of the other line (suction line) in there you check the low pressure (68psi) and if is low you can rechrge it, in the high side you should have no much more than 250psi .This pressures are for R22.
Apr 25, 2009 | Heating & Cooling
It is possible to delete a lost 4 button remote key chain
Obtain the installation manual. You should be able to find this on Google. Search for Ge Simon 3 install manual. Follow te instructions for deleting sensors.
Jan 25, 2009 | GE Security Simon 3 Wireless Home Security...
Saeco magic deluxe
use a little steel wire in the hole in the pipe to remove old milk residue you dont have to go to deep in the pipe 1 or 2 inch inside you have to remove the black plastic piece that goes in the milk thanks pierre
Jan 14, 2009 | Saeco Magic De Luxe Espresso Machine
GE Quiet-Aire Ductless Mini Split System Air Conditioner Logo
357 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Todd B
danoyachtcap
danoyachtcap
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
