Jvc hd61z886 lamp doezn't come on - Televison & Video
I ordered serrvice manual and will solve the problem.
I am very surprised you didn't give me professional assistance. What another assistance exist?
Anatole
Posted on Dec 17, 2008
How do i take the back off /jvc hd61z886?/ i am tring to replace the bulb.
There are arrows pointing to the screws necessary to remove the back.
Aug 08, 2015 | JVC Televison & Video
How to replace a lamp on my jvc tv
If you haave the original manual, this is discussed at the start of page 91. If you dont have manual, it can be obtained at books.jvc.com
1. Purchase lamp TS-CL110UAA
2. Turn Off and unplugg set
3. Remove lamp cover located on the left side of TV
4. Remove and replace lamp
5. Reset lamp counter in menu for accurate hour information.
Jul 26, 2014 | JVC HD-52G786 52" Rear Projection HDTV
How to install lamp
Hi.
The lamp is located behind the front panel. You need to remove the left speaker panel first, then remove panel and lamp cover held by a single screws.
The full instructions are explained from page 94 of the user manual.
The user manual in PDF format is available at the link below:
HD61z886-Rear Projection TV-User Manual (Click here to download the PDF)
Regards.
Ginko
Dec 16, 2011 | JVC Lamp For JVC HD61Z886 OWIZ136606388001
HOW DO I REPLACE THE LAMP
Hello
To replace lamp in JVC projection TV follow the steps below.
[1]. Order a compatible replacement lamp from JVC. Order a replacement lamp from JVC's Accessory Store or a local authorized parts distributor to ensure that you obtain a compatible replacement lamp. To order a replacement lamp, you must have the lamp type and lamp code of your JVC projection TV, which can be found on the rear of the television.
[2]. Turn off the television and allow the bulb to cool. For safety reasons, turn off and unplug your television before accessing any of its internal components. Wait at least 20 minutes before attempting to replace the lamp so that it has time to cool down. If the back of the television is not warm or hot to the touch, it is safe to begin removing the lamp
[3]. Unscrew and remove the lamp door. The lamp door on JVC projection TVs is located on the rear left of the television and is shaped like a square. Several warnings related to the lamp will be printed on the door. Use a Phillips-head or flathead screwdriver to remove the large screw, then remove the door
[4]. Unscrew and remove the lamp assembly unit. After you have removed the lamp door, you will see the lamp assembly unit. Use a Phillips-head screwdriver to remove the two screws. One screw is on the top right corner of the unit and the second screw is on the bottom left corner of the unit. Detach the lamp assembly unit from the compartment by lifting the handle and pulling the unit away from the television
[5]. Install the replacement lamp and secure the lamp door. Hold the replacement lamp assembly unit by the handle and insert it straight into the compartment. Reinsert and tighten the two screws onto the lamp assembly unit with a screwdriver. Place the lamp door back onto the television and tighten the screw to secure it to the television
[6]. Reset the television's lamp timer. Press "Menu" on the television's remote, then scroll to and select "Lamp Timer Reset." Press "OK" to rest the timer. A prompt will appear notifying you that the timer has successfully been reset
May 18, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
Hey i just replaced the lamp in my jvc 61' tv and needed to know how to reset the time
Scroll down the menu till you see "Lamp Reset " press Enter and your done..
Apr 22, 2010 | JVC Televison & Video
No picture
The lamps life span is 1 - 3yrs, Purchase your lamp directly from JVC.com $199 they back up there products. Good luck
Jan 27, 2009 | JVC HD-52G786 52" Rear Projection HDTV
JVC TV lamp indicator light blinking new lamp
if you purcased a LTI lamp then the possibilty of a bad lamp may be the case. LTI lamps are cheap and are poorly manufactured. if it is a JVC lamp then you may have further problems such as lamp balast, or thermal sensor. clean the fans and filtersfor better air flow. keeping the lanp cool is important for the life of the lamp.
Apr 19, 2008 | JVC HD-61Z575 61" Rear Projection...
Lamp going out on jvc flat screen tv 52 inch,how do you change
Versed, you have to open the back panel (cover) to access the lamp. replacing is easy as soon as you can see it. loosen the mounting bolt and pull to unplug the lamp from the SMPS Lamp power supply. Thats it.
Dec 21, 2007 | Televison & Video
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
