Question about Kenmore 78812 / 78814 / 78819 Gas Kitchen Range
Flint on the electric ignition of oven is broken, need to replace
The part that lights up to start the oven is broken. How do I replace and can I buy this part at a home improvement or appliance parts store
    President:
  • 331 Answers
Hey DM,
The part in question is called an igniter and can be purchased at your local appliance parts retailer.
It's not that difficult to replace the igniter. I can't give you an exact part number, but it'll be either the round style or the flat style. (You really don't need to know the part number, just ask your appliance parts guy for either flat or round igniter. They are both universal as far as brands are concerned. But if you're the curious type here are the numbers; Round= 4342528 and Flat= WB2X9998. Don't use the part numbers I linked to, above. The numbers there are specific to Repair Clinic, and NOT actual OEM part numbers)
Now for the fun stuff... the actual repair!
PULL THE OVEN OUT SLIGHTLY, REACH BEHIND IT AND UNPLUG IT!!!
Tools required:
1.) 1/4" socket or nut driver
2.) Flat or Phillips screwdriver
3.) Pliers
4.) Wire cutters
5.) Wire strippers
Remove the racks and then remove the "floor" panel of the oven. Then remove the diverter panel (might be a 3/8" nut or a wing nut... use the pliers here). Basically, you disassemble the entire bottom of the oven. You may need to pull the lower drawer out, as well.
After you have gained access to the igniter...you'll see that it's attached to the main manifold with two 1/4" screws. Word to the wise, here... use a little bit of liquid dish soap on the threads BEFORE trying to un-screw these. This will lubricate the threads and keep them from stripping. If you don't heed this warning and they strip? You'll have to grind them off in order to get the igniter removed.
Wire cutter time... snip the 2 white wires about 3" from the base of the old igniter. Wire stripper time... strip those 2 wires about a 1/2".
Now the old igniter is out. Pull out your new igniter. Cut any extraneous stuff off the END of the wires then strip them about a 1/2". Now mount the new igniter to the manifold (where the old one came from). Now take one wire (doesn't matter which one) from the new igniter and twist it to one of the wires you cut and stripped while removing the old igniter. Then use one of the ceramic wire nuts (included with your new igniter) and twist it on the exposed wires clock wise. Make sure there is NO WIRE EXPOSED after doing this. If there is, remove the wire nut and cut a small amount of you twisted wire pair off.
ALL OF THE EXPOSED WIRE SHALL BE INSIDE THE WIRE NUTS.
Do the same thing for the other wire. Now tuck all of the extra wire away. At this point, you're ready to test your handywork! Set it to bake and watch her light up!
All that's left to do now is rebuild the lower oven, grab a coolada and get some cookie dough. I'll be over at 6:00 for snacks :-)
SG
Posted on Mar 20, 2009
HOW DO I REPLACE THE FLINT OF A ZD41 LIGHTER
You've posted this in the car and truck section. I'll try and help.
Is this a higher quality refillable lighter? If it isn't refillable i wouldn't waste time replacing the flint. Just buy a new lighter. Are you sure it has a flint as some lighters have electronic sparks.
Try gently pulling the roller straight up. Some makers fit the flint as a pull out so you can replace the flint from below the roller.
If you really need to change the flint you will have to lever out the roller. NOTE, the flint will be spring loaded so might pop out as you remove the roller.
Feb 05, 2018 | Cars & Trucks
How to change the flint on micro torch roburn mt-770
There is no flint.
It uses a piezoelectric igniter. Not really replaceable.
Point it at yourself at arms length and see if you can see a spark when you press the button to start it.
Here is a video which shows how to adjust the air-gas mixture when the torch is new.
Jul 21, 2016 | Miscellaneous
How to change the flint on micro torch robin mt-770
There is no flint.
My oven won't light. is it the flint that needs replacing or do I need a new oven?
unless it is a really really old oven then it will have a pizo as a starter
if it is nor sparking when you press the button then get a gas technician to replace it or fix the jet fault.
May 20, 2015 | Ovens
Blazer pocket micro torch will not spark. Gas comes out, but no spark to ignite it.
try to open up the part where the spark would come from. there should be a screw on the bottom or top to open it. This is where the flint would be.
The flint is probably worn down or it broke (you can buy new flints at pretty much any convince store around they are i believe $1-2 for 5 of them.
replace the flint and you will have a spark.
May 03, 2011 | Omega Blazer Self - Igniting Butane Micro...
Burners work properly. Stove won't heat. Pilot light is out. Won't re-light with a match. When the stove is on the rectangular flint block heats up and glows orange.
Hi, Jus because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 14, 2010 | Tappan TGF657 Gas Kitchen Range
MY KENT GAS HEATER WILL LIGHT WITH A MATCH SO GAS IS GETTING THROUGH BUT FLINT IS NOT WORKING TO IGNITE THE FLAME/GAS
Your igniter may well be a Piezo Electric device... a spring loaded hammer strikes a crystal and the crystal generates a high voltage which causes a spark. They sometimes break down mechanically and the hammer no longer hits the crystal. You can sometimes repair them (rarely) and sometimes buy a replacement unit.
May 09, 2010 | Heating & Cooling
Oven won't light
I am assuming this is a gas stove. You probably need a new flint in the igniter. Simple problem. Check your local hardware store for flint, and refer to your manufacturer's manual for how to install it. If it's not there, a quick call to a service technician should answer the problem. hope this has been helpful.
Oct 24, 2008 | Ovens
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Kenmore 78812 / 78814 / 78819 Gas Kitchen Range Logo
1,054 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
