Question about Toshiba Satellite A135-S2276 Notebook
Usb ports not recognized
Have you had any success yet? Mine still isn't working, and Toshiba support isn't interested because it's out of warranty. Although this problem happened shortly after the BIOS password defect locked up my computer, which Toshiba did fix.
  • yocarol Dec 28, 2008
    ALL of the sites you offered lead to Driver Detective, apparently the most pervasive program on the net, but I tried it early on, and it didn't fix my problem.
  • Ron
    Ron May 11, 2010
    Have you gone into the bios and enabled the usb ports?
    Sometimes when the bios is reset it goes to factory settings and sometimes things get messed up.
1 usb port on toshiba satellite c660 doesn't recognize mouse
If is just a USB port, then it could be a driver problem, or that USB hub is turn off, or is a fried/bad USB port. Try another USB device on that port too.
Mar 19, 2012 | Gigabyte GA-8I845GVM-RZ Motherboard
Need my c650 usb driver
As Windows an operating system Toshiba Satellite C655 and C650 laptops and the USB port(s) are not working, run a DIAGNOSTIC TEST.
If the test will reveal that you have no problems with the USB divers, but your ports are not able to recognize the ports the problem may occure from the installed software. It happens that one ore more drivers to generate a "conflict" with that USB driver.Go to SYSTEM RESTORE and check the restore point of an earlier time. This is a SUCCESS AND FAILURE tests so keep rolling back in time until you will make it working.
Mar 06, 2011 | Toshiba gigabeat cradle USB Driver
USB ports not working. Any ideas?
In that case ,
Click on start and run
Type devmgmt.msc
Then uninstall all devices under universal serial bus controller.
Then need to click on any option in the list and scan for h/w changes.
This will install all devices back and your system will be able to recognize all devices now.
Hope this help.
Cheers!!!!!!!
Jun 21, 2009 | Toshiba Satellite A135-S2276 Notebook
My usb flashdrive is not recognized on any of my usb ports on my Toshiba satellite m35x-s163, can you help?
Test usb port with another device,
check in my computer for the drive,
Test usb flash in another Pc,
Manufacturers website for a possible driver.
if still not working then it's faulty,
Regards
Rpf
Apr 14, 2009 | Toshiba Satellite M35X-S163 Notebook
Toshiba satellite A135 USB troubleshoot what ever i plug a usb device... the windows tell me usb not recognized and then the window say usb installed successfully and ready to use but the device is not...
be careful using hubs with this model mine didnt like them,if yours is the model with sd card reader in the side try sloting a card in if it dosent pick that up then you will have to load windows on again problem with usb internal settings,if this is the problem it picks up the device but you cant access it.
Dec 06, 2008 | Toshiba Satellite A135-S2386 Notebook
Toshiba satellite a135-2326 usb not recognized
its a driver issue most likly down to vista (as always) have you tried the latest updates from the microsoft website yet?
Aug 11, 2008 | Toshiba Satellite A135-S2386 Notebook
USB Ports Not Working
Check Device Manager for bad drivers
Aug 09, 2008 | Computers & Internet
NO USB WORKING
Hi there what OS do you have loaded?
Im assuming you have XP loaded.....
have you tried to unistall and reinstall the USB ports?
reboot and restart,
should auto recognise the device and self install,
reboot and restart,Test usb
dont for get SP2 updates for functionality of the devices
Let me know the outcome thanks
Jul 21, 2008 | ASUS P4P800-MX Motherboard
USB Ports
I would go back to device manager and uninstall all drivers in the USB category. Reboot and Windows will re-detect all the USB ports, this should work. If it was an electronic problem then some ports would work and other wouldn't but not all since there is multiple USB controllers in most computers these days.
Jun 16, 2008 | Toshiba Satellite M35X-S114 Notebook
HEY HEY HEY!
guess u wat? my usb came back to life! just like that! may be God exists afterl all, does He???
Jun 06, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
