Question about Hoover Windtunnel Turbo Power U4645-930 Vacuum
My girlfriend has a Hoover upright vacuum, Mdl. # U4645-930. I need a belt for the brush and a new bulb and am having trouble finding the correct part numbers so I can pick one up locally. Can you help?
  • 32 Answers
I checked with Hoover and they said the part number for the belt is #38528040, for the bulb #27313101, and they also included a part number for something called an agitator #48414081. Not sure if this is required to replace one of the other parts. You might ask when ordering. To order, call 1-330-499-9499 or online at www.Hoover.com.
Posted on Jan 22, 2009
How do i know if the belt needs to be replaced in my hoover spin scrub
Remove the brush cover. Check belt for cuts or stressed areas.
Is the belt taut or stretched to the point of being loose. If you see
any of this replace with the correct size. Pull brush bar out of the
side slots and remove belt from motor pulley. Place new belt on
pulley and onto grooved area on the bar....stretch forward and
push back down into side slots. Remember....groove in brush bar
must line up with pulley. This is also a good time to remove hair
and other stuff from the brushes and bar.
Regards,
Dennis
Aug 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How do you replace the beater bar belt on the hoover u 6626-900
It is not a "Beater Bar". Hoovers have brush rollers and are easy to replace. Turn the machine over and remove the 4 screws which hold the cover on, over the brush. Remove the brush roller. Slide the new roller through the small belt (self propelled models) and secure into slots (note: slots are different, match roller sides to correct slot.
Sep 20, 2011 | Hoover U6630-900 WindTunnel Bagless...
I have a Hoover Windtunnel U 6439-900. The agitator brush will not turn. I installed 2 new belts, # 38528034, and # 38528-035 There is so much slack in belt # 3852034 (brush drive) that it cannot grip the...
There is an idler pulley that takes up the slack in the V belt when you pull the handle back to vacuum. Make sure it is engaging properly and the V belt is installed correctly.
Sep 09, 2017 | Hoover U6630-900 WindTunnel Bagless...
Hoover WindTunnel Self-Propelled V Belt
when you released the end to slide the new belt on it allows the tension roller to slide into the wrong position. Remove the top so that you can see the roller, at the left side of the roller mechanism there is a screw, loosen it enough to allow the roller to return to the correct position.
good luck
Mar 23, 2009 | Hoover U6441-940 WindTunnel Bagged Upright...
Brush roller on Hoover upright stops turning
There should be a belt tensioner for the V belt, maybe it is not contacting the belt when you tilt the handle back. If this is less then 1 year old, then it is under warranty, take it in to a warranty servicer for warranty repair.
Dec 13, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Wind Tunnel V-Belt no longer turns brush
that is the correct belt what you dont see is a tension pulley that when the handle is released pushes on top of that belt giving it the tension it needs. try replacing the other belt, even if it isnt broken it could easily be stretched out ( all belts of that type should be replaced every year - even if you didnt use the machine at all ). if that doesnt work that tension pulley could be damaged you would need to take the bottom of the machine apart to fix that.
Sep 18, 2008 | Hoover U6311-930 Power Drive Bagged...
Changing the belt?
Take off the bottom plate covering the brush roll. The belt runs from the brush roll to the motor shaft. Get a new belt, it will strectch to go around both.
Apr 29, 2008 | Hoover U5163-900 Upright Vacuum
BELTS ON WINDTUNNEL VACUUMS
Greetings from GoVacuum,
Here's an instructional video that we made showing how to change the belt on a Hoover Windtunnel upright. If your model is not a self propelled model, basically follow the same insturctions, expect instead of placing the belt over the pulley, just put the belt through the roller brush, and stretch the roller brush back into the agitator housing.
Please feel free to send me an email if you have any other questions. My email address is chris.jones@govacuum.com.
Thanks,
Chris Jones
GoVacuum.com
Mar 16, 2008 | Hoover U5753-900 WindTunnel Bagless...
Hoover Windtunnel Turbo Power U4645-930 Vacuum Logo
123 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
