Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitach 52" rear projection tv
After being on for awhile the screen switches to what i would describe as a negative image and has white wavy lines. If i turn the set off and on it goes away for a while but comes back. The screen also has a red half moon dot in the center now. I cleaned the circit boards with air and they seem to be in good condition. The tv has always been well cared for. Any advice?
  • damian farrugia Mar 21, 2007
    wow. I just learned alot about my tv!
    Ok, so i took off the screen, cleaned it and the mirror. Took off all three lens and cleaned them (and there was debris inside) when i look inside the tubes, there is a black half moon shape inside all three. could three tubes blow at once or could there be a pre-tube problem? also it hasn't done the negative thing since i opened the lens?
    President:
  • 3,130 Answers
The problem you have with the picture is a problem with the video circuit. Most likely a coupling capacitor or the Y/C Video Jungle IC. the half mood on the picture could be a seriuos problem though. You will need to take off the front screen and while the set is on, look down all three picture tubes. Is there what looks like a spot on one of the pictubes surfaces? If there is, that tube is going to have to be replaced. If it looks like something floating around inside the tube, maybe the tube can be disassembled and cleaned.. Also check the mirrors inside the set and on the surface of the three lens, maybe there is a spot on one of those. Good Luck.
Posted on Mar 21, 2007
  • Larry  Dillon
    Larry Dillon Mar 21, 2007
    That is a burn on the picture tubes my friend,, i would call up Panasonic as this set is suppose to have protection circuits built in to the set to prevent this from happening. Great that you cleaned your set.
Picture show blurred and 3 lines across the screen color of red, blue and green
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
When you turn on the the TV the picture is good with in a minute or so the Picture turns wavy and has a double image. I can turn it off, then turn it right back on the picture is good for any where a...
The problem with the television is the lamp. It is faulty that is why the screen turns wavy in minutes.
The solution to that is to replace the light and your television will be in good condition once again.
Take care
Oct 10, 2010 | RCA P52926 52" Rear Projection Television
Thin vertical lines
Those lines are called retrace lines. They are there all the time on projection TVs but you should be able to see them. When you do see them, that's an indication that the kine screen settings are too high or the supply voltage to the kine driver circuit is low or missing. There is a small, black control unit located behind the speaker grill assy in the front of the TV that has 2 sets of 3 controls. A red, blue, and green focus and screen controls. See if you can make the lines dissappear by turning the screen controls counterclockwise. If you can't you'll need to have service come out to troubleshoot it.
michtech
Feb 02, 2009 | RCA D52W19 52" Rear Projection Television
RCA 2005 52 inch HDTV
you ca take the scren out and clean it as far as the other problem u may want to call a service tech in
Sep 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
1999 zenith 52 inch rear projection screen t.v.
IS the screen white retrace lines ? Have you looked into the CRT lenses while they are on with a signal applied through the input to see if an image is displayed in the lens lens of the crt? Let me know what the answer is to these two questions and we will go to the next level.
Apr 10, 2008 | Zenith B50M88W 50" Rear Projection...
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Hitachi 43UWX10B 43" Rear Projection Television Logo
62 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
