I have a 2002 jeep liberty, an my left side turn signal an left side 4ways wont work, but the right side works great. An also my radio only works for about 15 seconds then cuts off
As Brett says, it might be a faulty turn signal switch. It may also be bad grounds somewhere. It does appear to be a known issue, and there are some other ideas here.
Check the wiring on that light. Also check the bulb with a couple of wires to the battery, or swap the bulb left to right to make sure the new bulb is okay.
Normally when this happens you have a blown bulb on either the front or rear the fast blink is because with only one bulb working the flasher clicks it faster less of a load means faster blink.
Signals are now controlled by a module on the right side of the steering column under the dash. Before doing anything yourself, bring it to the attention of the guys that did the rear...This problem can happen at any time but they may have disconnected a harness or ground while working, so give them a chance first to correct it.
where is the flasher and or fuse located on this 2002 jeep liberty
