posted by Arielle on Mar 21, 2007
Besides restarting the fax, unplugging and replugging all components, what general troubleshooting techniques for outbound faxing can I use? The fax dials out and it sounds like it's beginning to go through, but then the paper isn't being drawn from the tray at all.
Thanks!
2 Other Users Have The Same Problem
Comment by algernon, posted on Dec 11, 2007
Used machine. All setup complete. Fax will not send even though the receiving station answers. Will copy OK but paper will not go out in Fax mode. Double checked setup. Fax signal heard till "start" pressed, then a different sound, not normal fax sound.
Comment by Guest, posted on Nov 09, 2007
It rings and the other side fax accepts the call but no movement on 1270 and than it says awaiting Redial.
Best Solution
posted on Jan 30, 2008
You obviously you mustn't have the phone line plugged in properly or have not payed a bill to phone company
Hope this helps - Josh
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Brother IntelliFAX 1270E Plain Paper
Email this problem
Email this problem
Can you Help with these Fax Machines problems?
Brother IntelliFAX 1270E Plain Paper Fax
Brother Intellifax 1270e...
Hi, I'm trying to delete a... Answer This...
Faxes not going through
Hi When I send a fax the cover... Answer This...
Brother Fax 1270-time setting
The time on our fax machine... Answer This...
Repair Service
Find Fax Machine Repairman Near You:
