Question about Whirlpool GEW9200L Electric Dryer
Heating Element for Whirlpool Dryer: GEW9200LW0
I can't figure out how to install the heating element. I don't know if it goes in the front or the back of the dryer. Please help!!!
  • 161 Answers
I think on this one you can take off the bottom panel on the front and get access to the heating element.
Posted on Dec 16, 2008
My dryer whirlpool still blow cool air but do not heat please tell me what the problem henry le
Bad heating element or bad thermo fuse.
You will have to unplug the dryer and remove the back to access the heating element. The thermo fuse is located on the side of the heating element.
If you don't have a meter to test the element and thermo fuse or just don't know how simply remove them from the dryer and take them to your local appliance repair shop and they can test them for you.
Aug 03, 2011 | Whirlpool LER4600 Electric Dryer
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly.
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Can't find the heating element on my admiral dryer ade7005ayw
Normal 0 Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the element on the right hand side. Plug the dryer in to test to see if there is 240V going to the element posts. If there is voltage, but no heat, change the element. If it does not, you need to test the thermostats for continuity. If any of the thermostats are open, replace it. I hope this helps you.
Please let me know if this help or if I can assist you further.
Jun 13, 2009 | Whirlpool LER5636P Electric Dryer
Replaced bad high temp sensor and two loads later it is bad
It will continue to blow until you correct the blockage in the vent system.
It may be internal to the dryer or external to the connecting vent or outside vent.
Find it and fix it.
Mar 12, 2009 | Whirlpool Dryers
Whirpool duet dryer mod GEW9200LW0, working but not heating up
If it's starting and not heating it's usually one of two things. Take off the bottom panel. 2 screws hold it in place. If you have a way to check the element with a meter or something that would be ideal. It should read about a short circuit. The other part that goes out a lot is the thermal fuse located in the front on a pipe it's long and narrow. Here is a link to show where things are in there. Let me know if you have any more questions!retrieveModelDetails.pd?modelNumber=GEW9200LW0&productCategoryId=0151200&brandId=1198&modelName=DRYER
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9200LW0 Not heating
You need to remove the back panel first then with a multi meter the easiest way is to put the meter on continuaty test (beeps when contact is made then with the dryer switched of and unplugged put one probe on the one side of the element and the other on the other side if it beeps then your element should be ok if not one of two things (1) Your element is blown or (2) there should be a fuse around the area of the back support plate it may be a normal round fuse or a ceramic round fuse or what looks like a brown rectangular piece of plastic with a wire out each side test the fuse in the same way as you tested the element if blown replace if not then put in a element.
Jan 22, 2009 | Whirlpool GEW9200L Electric Dryer
Whirlpool GEW9200L Electric Dryer Logo
226 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
