Question about HP Compaq nx9420 Notebook
The latch lever in the middle of the top has come off
Is there anywhere to purchase the outside piece for the latch for an NX9420? The latch itself works fine but the outside piece that you slide to the right has broken off.
Passanger side door locking problem. when I insert the Key, it can turn forward to lock the door, but can not turn backward to unlock the door. And I tried the second key, does not work either.
Really sounds like one of 2 possible problems.
First, perhaps the door latch itself is broken, and that is unlikely, except that I am unfamiliar with that particular latch on that particular car.
Second, it sounds like, if you were to take the door panel off, you would find the latch is locked because one of the locking levers is holding the door latch locked.
There or 2 or 3 lever like things that affect the latch.
There is a lever from the outside door lock that goes to the door latch.
There is a lever from the inside locking handle that goes to the door latch, and yet may be one more.
If any of these are "stuck" or broken, they will "hold" the door latch in the locked position.
Be blessed.
Feb 07, 2013 | 1998 Nissan Altima
How do I install a new Handle/Latch assembly on the door of a Whirlpool LHW0050PQ 4 Wash Machine...have to remove present one as broken---pull handle door catch does not release---have to release putting a...
I had to replace part No 8182408 - the washing machine door handle. There is a plastic bar in the middle of the assembly that broke because the door was opened too hard.
There are two springs, the latch, and the plastic piece that brings it all together. The smaller spring is the key, call it the L spring. It is shaped like an L and goes around the ends of the latch. The other spring is the larger and straight and goes around the tops of the plastic piece. The straight spring goes in with the crossbar facing on the outside of the washer. The latch with the L spring fits in between the plastic crossbar with the U shaped end pressing against the latches inside bar. The antenna of the L spring needs to wrap around the plastic bar and fit inside the straight spring bar. This applies pressure on the latch to stay closed. When the handle is pulled, it releases the pressure and allows you to open the door. The Metal bar is used to hold all the pieces together and once you have the alignment right, put it back into the door with the straight spring antenna tucked in the spots on the door, as well as the metal bar ends. Screw in the two spots that holds the assembly in place and you will be set. The door should open and shut easily.
Apr 22, 2011 | Whirlpool Washing Machines
I ordered the n64 without any additional partsw with the domkey kog game. Ehen it was plugged in it said on the screen another expansion pak was needed. I bought that but do't know where it goes. Help...
I assume you purchased the graphics card expansion pack (essentially it is a larger memory module for graphics) Most of these have a red crosshatch pattern on the top side.
Open the small latch on the top of the console and remove the module you will find inside. A flat blunt screwdriver will do the trick if a lever was not included. Once you pop that piece out insert your new one in the same orientation that the old one was in. Then replace the latch and that's it!
Mar 09, 2011 | Nintendo 64 Console
Knoica minolta 250W printer cartridge jamed lever and mechanism cam off I cannot move it now thw whole machine has jammed what can I do please?
OK... YOU HAVE TWO POSSIBILITIES... EITHER THE LEVER ON THE TOP COVER BROKE OR THE ONE ON THE PRINTER CARTRIDGE...
IF ITS THE ONE ON THE TOP COVER THEN YOU NEED TO REMOVE THE LEVER HANDLE COMPLETELY AND GET A PLYERS AND USE IT TO TURN THE METAL THE LEVER IS ATTACHED TO OR FIGURE OUT WHERE THE THE LEVER GETS THE MACHINE TO LATCH AND USE A FLAT HEAD SCREW DRIVER AND SLIP THE LATCH... THEN CONTACT KONICA MINOLTA AND PURCHASE A NEW LEVER...
IF ITS THE TONER LEVER THATS BROKEN... YOU ARE GOING TO HAVE TO GET A PLYERS... TAKE A FIRM GRIP ON THE TONER AND REMOVE THE TONER IN THE SAME WAY THAT YOU WOULD IF THE LATCH WAS THERE... IF ITS BEEN PUT IN ODD THEN IT MIGHT BE STUCK... YOU MIGHT NEED TO USE A FLATHEAD SCREWDRIVER ON THE ENDS TO HELP THE PROCESS ALONG...
USER MANUAL
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Feb 12, 2011 | Konica Minolta magicolor 2500W Laser...
My car door does not close,door lock is jamb
Check the latch assembly where the door closes. If the latch claw is closed it won't latch. Make sure the door is unlocked. Insert a screwdriver into the middle of the claw (circular opening where the striker latches). Open the door handle from inside or outside and pull sideways on the latch it should pop open. If it doesn't then the lock mechanism is in the lock position. Remove door panel follow lock rod to the latch and manually try to move the lever to the unlock position. If all fails you probably will need a new latch assembly.
Jan 30, 2011 | 2000 Ford Taurus
Left drivers door will not open from inside it does open from outside how to repair
you will need to remove inner door panel, either the handle itself broke where the rod connects,or the rod fell off or broke at the door latch, or the door latch lever bent or corrodded, the outer and inner handles use the same door latch but not the same mechanisms or rods to operate the latch. Once you remove the door panel and the inner dust shield with the window up look in the bottom of door for clips or a rod or broken parts. and note latch and handle for boken or bent and missing pieces. once you start looking it all becomes self explanatory.
Jan 15, 2011 | 1999 GMC Suburban
KUDS24SE KitchenAid door latch broke. How do I take the door apart
If the door cannot be opened, remove the the outside lower panel. (2 screws at bottom of panel, then lift off. Take a long screw driver (be sure power is removed first!) and push up behind the control panel at the latch at the very top middle of the door. You can them open the door and remove the screws that hold the control panel on. When the control panel is removed you will have access to the door handle and latch pieces. These parts can be ordered through sears partsdirect web site. Good luck.
Jan 09, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
2000 Chevy Blazer with Broken Hood Release. How do I open the hood
can you reach the cable itself?,or is it broke at the hood latch?IF its not broken at the outside latch, try to follow the cable,un-hook it from the handle and pull on the wire cable to open it.IF its broken at the latch itself,you are going to have to reach the latch through the grille and try to pull the lever the cable connects to.That part is no fun at all..!!
May 09, 2009 | Chevrolet Blazer Cars & Trucks
The "Paper Jam" light on my Sharp AL-1631 copier stays on
The paper detector on the fixing units have a history of going bad. The fixing unit is the hot roller above the drum inside the right door on the top. As the copy comes thru the rollers the paper hits a plastic lever that is spring loaded and located in the middle of the fixing unit. The sensor is all the way to the right side of the fixing assembly. If you move the lever in the middle you'll see a piece of plastic moving on the right, that piece comes out of the sensor and if can't reset the jam, that piece may not be resetting itself back inside the sensor. This is difficult to try to explain.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
Drivers rear door wont open from outside child lock on the inside
You will have to pull of the door panel, but most likely cause is the lever from the handle to the latch is disconnected, or possibly the latch itself may be loose/malfunctioning.
Mar 07, 2009 | 2004 Toyota Sequoia
HP Compaq nx9420 Notebook Logo
165 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
