Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Won't turn on
Our tv won't turn on. The power light flashes 9 times and then 5. It is only slightly over a year old and Rca says the warranty is out.
Replace the small signal board and take the eeproms off the old board put on new board to avoid convergence alignment and geometry problems
Posted on Jun 21, 2007
  • 203 Answers
If the TV is only a few weeks past warranty you can call and pester RCA and they usually will give you a concession on a repair....it's worth a shot.
Posted on Jun 09, 2007
  • 67 Answers
Also i know if u call sears they offer a warranty on items already broke its a little more expensive but worth a try
Posted on Mar 22, 2007
    President:
  • 3,130 Answers
That is a shame a company like RCA will not stand behind thier products if the warranty just runs out. Were you offered an exteced warranty at the time of purchace. if so go back to the store and see if it is too late to buy one. Then next week call the servicer and say the TV went out. I have heard of this being done before. Good luck.. The problem with your TV set is most likely the power supply. unless yopu have electronic test equipment, this could cost you big bucks.
  • Larry  Dillon
    Larry Dillon Mar 22, 2007
    Thats an extended warranty, sorry about the spelling.
  • byrdmnjr Mar 12, 2011
    is this problem fixable without a shop??? i am having this same problem..
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
My "50" RCA Scenium won't
That's usually caused by a bad lamp. However that chassis is famous for having bad caps on the power board. The repair kit is available at the following link and has repair instructions included. http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
Aug 16, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
I have a 52" RCA
sounds like the power supply capacitors CP150, CP120 and CP114 need replacement. You can get the RCA repair kit by that same name from www.tvrepairworld.com which has the caps and the CD with repair instructions.
Aug 05, 2011 | RCA HD52W56 52" Rear Projection HDTV
My 20" rca 20f424t cuts
That sucks about your tv. Mine just turned 3 years old. Never had a problem with it. But you seriously can't expect wal-mart to take back and exchange a 3 year old tv. Come on. That would be stupid for walmart to do. Even RCA prolly dosent do more than a 1 year warranty. Unless you purchased the warranty from walmart, it will be cheaper to just get a 19 inch lcd tv now. Cheapest I see them on sale for is only $99.99
Aug 02, 2011 | RCA 20F424T 20" TV
I have an rca 61" dlp tv that is about 4 years
More than likely you have a power board that is failing. Since the TV is so old I doubt it is under warranty still. I estimate it would cost you anywhere between $300-400 to repair that problem so it may be time to switch to a newer LCD TV.
Feb 28, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
My rca tv power light is flashing it flashs 9 times then 5 times what does this mean
Power supply board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a reburbish power supply board for the replacement.
Thanks for using fixya............
Aug 16, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv will not turn on the power light comes on
After the power surge , the TV went on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur after power surge on a rear projection are a blown capacitor on power board, a component on ballast board has blown, or a fault on Digital board had occurred.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Sep 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
Power button malfunction
Sounds like a faulty power supply. Consult warranty guide if its still under warranty, if not, you really need to consider calling a repair technician
Feb 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA SCENIUM trys to start up but wont start
I kind of had the same problem..I had audio..no picture..and the display would flash 5 times. Per the manual it said the lamp needed replaced. After reading a post by someone that had the same problem and replaced the lamp, it still didnt fix the problem..I took my set in to the repair shop. Turned out to be the light engine..$1000.00 for the part...$250.00 for labor! The tv was only 15 months old..and not even used on a regualr basis..I maybe had 300 hrs on it. I did not buy the extended warranty (will for my next tv!!!) but after many heated conversations with RCA..they agreed to pay for the part..I got stuck with the labor, atleast that was better than the whole bill. Anyway..starting to act up again..after only 5 months..bottom line..I'll never buy an RCA again!!
Oct 29, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
146 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
