Question about Dell Latitude D800 Notebook
Dell Lattude D800 HDD change - doesn't boot
I changed my Seagate 40GB hard drive for a new 160GB WD Scorpio. The Seagate was copied using ghost, but xp didn't start from the new hdd. I got some error message. The bios version is A13, the latest one.
What's the max supported hdd size of this notebook/i855PM chipset?
  • aromo Dec 16, 2008
    Thx, bios is the latest release. Bios showed 137GB. I think, this notebook supports hdd up to 120GB only.
    Guru:
  • Dell Master
  • 829 Answers
I suppose it can support upto 100GB , just get the BIOS updated to the latest release and check in the setup if the disk is accepted .
Posted on Dec 16, 2008
Upgraded HDD on D800 to 160GB drive. Worked fine for 2 wks. Shutdown and will not boot up. BIOS doesn't detect the drive. I can connect the drive to an external USB device and read all files on...
Could be an incorrect bios hard drive setting. Dell has a good customer service area. Did you use same type of drive SATA TO SATA? IDE to IDE? If you changed over there might be a setting to account for the difference.
Aug 25, 2017 | Dell Latitude D800 Notebook
Upgrade from 40GB to 250GB WHATS NEEDED?
I usually use a USB to IDE adaptor and software such as clonezilla
I hook up the new drive to the adaptor and then run clonezilla to duplicate the drive. If you are more experienced with other clone software such as norton ghost then use what you know best
Clone the drive and then just swap them out.
OR you could get one of those 2.5" external drive cases and use that to do the exact same thing so that when you swap the drive out you end up with a nice 40Gb external one too
prices for either the case or USB adaptor are very cheap and they are both useful to have around.
Hope that points you in the right direction
Bob.
Jul 22, 2010 | Compaq (201066-B21) 40 GB Hard Drive
I have bought new hard drive of 160GB Seagate IDE. because my HITACHI 250 GB sata drive was giving problem. i have installed O/S in my new 160 IDE. but the system is taking my old sata HITACHI as the...
At boot up press F2 to enter the BIOS. That is where the change has to be registered for your PC to recognize the new HDD. So when you get the first meny there you will find the HDD. If not, then auto detect the HDD. Within a second or two your new HDD will be recognized. Also from the back of the new HDD. ie, the Seagate, check if the Seagate is the master. If not, then you will find a diagram there which tells you how to change the jumper so that your HDD will behave as master. And I hope you are not using the other HDD as well?
Nov 01, 2009 | BenQ Cameras
I want to change the HD from 40Gb to one with more capacity but I tried to make a ghost image in a 120GB and 160GB HD but the bios don't recognize it and only can see in the screen a simbol _ flashing.
Not sure which software you are using for making the ghost image. Lets say its "Acronis".
First, you will need an USB hard disk drive to store the image on.
Next, run the boot cd and choose backup.
Send it to the hdd.
If it was successful, remove / replace your hdd.
Run the boot cd again but now choose "Restore". Locate your image and then wait.
Hope this helps you. Norton Ghost is a bit different.
Oct 20, 2009 | HP Compaq nx5000 Notebook
Will pata hard drive work on dell inspiron 600m? WD Scorpio Blue 160gb PATA drive
Yes, the Dell inspiron 600m uses the EIDE/PATA interface so your new drive should work fine.
Oct 04, 2009 | Computers & Internet
Longer Boot time after upgrading the Hard drive
first let's determine if the upgrade cause the boot speed.
Disconnect your NEW HDD and/or memory, one by one and see if you get back your fast boot. Then try with your NEW components only !
If you find it works better with new components only, then first connect your OLD HDD only and try.
If you connect both HDDs on one cable, check Jumper settings for both HDDs (Master/Slave).
Also HDD capacity and type is automatically detected by the BIOS and there is no need to put/change those settings manually.
I believe you new RAM is DDR type, too!
As written in the manual for the board, your motherboard has two pairs of memory slots, and you can use one or two modules of DDR memory, OR one or two modules of SDRAM memory, but you can NOT put BOTH DDR and SDRAM memory modules.
regards.
Apr 22, 2009 | Computers & Internet
WD Scorpio Black 320GB SATA drive
Halarious, I had the same problem yet I used norton ghost. At least you still show 160 gb. Mine went all the way to 60 gb. Here is what I had to do to reclaim the lost. I downloaded something called "Magic Boot Disk" It gave me the whole 320 back yet have not found good cloning software yet. Magic Boot Disc is freeware avaliable at http://hddguru.com/content/en/software/2006.02.10-Magic-Boot-Disk/ Good luck cloning
Feb 21, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Switching from 40GB IDE HDD to 500GB SATA HDD. SATA won't boot.
Hi there
No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
Good luck and thanks for using Fixya!!!!
Feb 09, 2009 | VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400...
Replace existing 40GB internal HDD in laptop with 160GB internal
Drag and drop the files from one drive to the other.
  1. Plug your new drive in
  2. Right click 'my computer'
  3. than open 'C drive'
  4. repeat steps one and two
  5. than drag the files from C' drive to new drive'
Jan 05, 2009 | Computers & Internet
Dell Latitude D800 Notebook Logo
190 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
