Question about Epson Stylus CX7800 All-In-One InkJet Printer
Epson all in one (printer/scanner)
I can print fine but when i want to make a copy or scan something it doesn't work it just say error.
  • 1,218 Answers
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Posted on Oct 04, 2010
  • 944 Answers
Here is the link for all the documentation, troubleshooting and drivers for your printer. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=58773&prodoid=56291070&infoType=Downloads&platform=Windows If you go through the troubleshooting guide, hopefully you will find an answer - with the info you gave I had no luck, but the procedure is quite detailed, so you may have more idea what answers to give. The next thing to try is to uninstall and reinstall the drivers - on the link above you can download the latest versions. This ,may solve the problem and is simple enough to do (ask for more help if you have trouble with this procedure). The only other thing that maybe worth doing is to give the whole machine a gentle shake just in case the scanner carriage mechanism is somehow jammed - sometimes a shake or a slap can free this. Hope this helps, if not please post again :)
Posted on Mar 22, 2007
My lexmark s605 doesn't work, but the pinter and copier are all fine
Plug in usb cable from printer directly to computer then print something. If you're successful, try to print something. If you're on wireless connection, disconnect the usb cord and try to scan.
Aug 27, 2012 | Lexmark "interact s605 wireless all-in-one...
My Printer Lexmark X4580 will not scan. I get the following message-Cannot retrieve Application List. Printing and copying works fine.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via the USB cable, disconnect your printer from your computer. Reboot your computer. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to scan again.
If that doesn't help, try to reinstall the printer software on your computer. This will help repair any corrupted files necessary for scanning or printing.
Jun 27, 2011 | Lexmark X4580 InkJet Printer
I have a Mac OS X 10.6.4 & an HP Deskjet HP 4480 Printer. The printer works fine for copying and for printing from the computer, but, when I try to scan something into the computer, everything works...
I had the same problem, found out that you should not install the disk that came with the printer. If you do it won't scan. The drivers are already in Mac OSX. You have to uninstall whatever you installed...throw the disk away. To scan go to System Preferences, click printer, then scanner button and it works. Hope this helps!
Jul 24, 2010 | HP F4480 All-In-One Printer
My hp deskjet printer can not copy or scan
Error message?
Just put something on the scanner glass and press the print button in the printer itself, leave the computer alone.
Did it work? if so... there's something wrong with the HP software, re-install.
That machine takes copies without the computer on, so, it should work.
Sep 12, 2009 | HP DeskJet F380 All-In-One Printer
Scanner error message. Will print from PC fine
The Scanner has died. If you Know someone else who has the same model but is not printing but scanning fine you can swop over the scanners. This solution don't work 100% of the time but i have fixed a few this way.
Apr 01, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Unable to print or scan - copy only
that is a networking problem the fact the you can copy eliminates the possibility that there is something wrong with the printer / copier
Mar 25, 2009 | HP Office Equipment & Supplies
Scanner and copier do not work
In your case, the scanner light is not lit during the scan or copy. If you print something from the pc, it would print just fine. Try to powercycle the printer, then try copying again. If it persist, scanner is defective but you may still use it to print from pc.
Mar 05, 2009 | HP PSC 2355 All-In-One InkJet Printer
Dell 924 will not scan
Try reinstalling the driver. Usually the scanning utility needs to be tied to an application like photoshop to process.
Oct 23, 2007 | Dell 924 All-in-One InkJet Printer
Epson Stylus CX7800 All-In-One InkJet Printer Logo
625 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
