Question about Sony BRAVIA KLV-40U100M 40 in. HD-Ready LCD Television
Sony model KDL-40V4100. PC input not detecting when using RGBHV
Can this tv use the PC input with only RGBHV connection on the HD 15pin connector?
Does it need feedback info from the PC? will it work using a switcher or a DA?
We send the signal about 50ft with an extender (extron) and it will not since a PC
  • 125 Answers
SOURCE: no signal sony bravia to dell laptop
Most laptops have a combination of buttons you have to press on the keyboard to get it to output on the monitor output. Try pressing the FUNCTION KEY or FUNC/FN key usually found in the bottom left hand side of the keyboard. Keep that button held down while press one of the number keys. Usually the number key will have a picture of a TV screen on it. Might be number 8 or 9. Press both keys at the same time a you can switch between laptop screen, Sony LCD or you can have both..
Posted on Mar 20, 2009
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
SOURCE: HDCP not compliant after hook up
We have hooked up our Sony HD TV Bravia Model KDL-46v5100. when we hook up the DVI connectores the message says not
HDCP not compliant, what does this mean???
Posted on Jan 01, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: I have a Sony KDL-40V4100, constantly hearing clicking noises
Could be the power board or main board defective, but I suggest you do firmware update first. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 download the software.
Posted on May 09, 2010
Testimonial: "I will try to update the firmware. Thanks !"
budmrtn
  • 11361 Answers
SOURCE: Have a Sony Bravia KDL-40v4100 Flat panel, had a
Check the main AC fuse, it may have blown because in the TV it has MOVs for surge protection that are installed after the main AC fuse, when the MOVs conduct, it will cause the main fuse to blow to stop any surge from coming through the second time.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Posted on Jul 27, 2010
Trying to connect Laptop VGA to TV Component (RGBHV) INPUT
Computer VGA to TV AV RCA S-Video Composite Converter, Costech HD 1080P HDTV Video Cable Converter Adapter Plug and Play for HDTVS, Monitors, Display, Laptop, Desktop, PC
Go to Amazon and for $10 solve the problem
Feb 04, 2018 | Mitsubishi Televison & Video
Sony TV model KDL-40V4100. What could cause a snowy white screen?
Tuner has to be checked and replaced. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 08, 2015 | Sony Televison & Video
Looking at a negative screen
Sony Bravia KDL-40V4100 models have a problem with the screen going blank, faded or washed out ( negative ghosting) . It is caused by a bad chip on the T-con board. A replacement chip is available from shopjimmy.com (Sony 55.40T02.C08 T-Con Board Component Repair Kit) for $14.95- If your not an excellent solderer, send your board to them for a repair $69.95.
Feb 11, 2014 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
I have sony kdl-46sl140.picture is blinking a nd channels and volume is disabled.
It could be something like an ETC-inverter board, or the power board. I have the same TV with a cracked screen. Are you interested in selling yours?
May 12, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
May 08, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Set up my comcast cisco box to my sony bravia and am getting a "no signal" message even though my cable in and hdmi connections are secured. please advise thx
Hi
Is this a new TV going into an old connection or an old TV going into a new connection? If this is a new connection I would get a hold of Comcast and make sure they have registered the boxes IP address. If this is a new TV then I would go into the menu and select the TV inputs. Go through these until you see an image. If still nothing then the new TV is defective. Good luck
Mar 13, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Sony bravia KDL-40V4100 audio and picture cycling on and off
I'd say about the blinking to a black screen would be your cable provider. As for the stripes that means that your board panels can be going bad, you can try updating the firmware of the TV to help but if that doesn't work you're getting very close to full failure on the TV.
Dec 14, 2009 | Dell E153FP 15" LCD Monitor
Sony Bravia TV automtaically goes on standby.
Probably the main board. This has a 1 year mfc parts and lobor warr. I would contact Sony for the nearest auth servicer. If you open it you will void the warranty.
Apr 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Clicking sounds when turning off Sony bravia kld-40v4100
ACTUALLY WITHOUT SEEING YOUR PROBLEM PHYSICALLY I CANN'T SAY ANY THINK, BUT FOR YOUR KNOWLEDGE LET ME TELL YOU NO TV MAKES ANY KIND OF SOUND DURING SHUT OFF. & you are saying for more than 30sec, i think you should call the SONY TECHNICIAN for visit.
Dec 20, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KLV-40U100M 40 in. HD-Ready LCD Television Logo
108 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
