Question about Sony PCS-1 (PCS1) Video Conference
Which mdel in Polycom is compatible with Sony PCS 1, which is better.
  • Anonymous Feb 06, 2009
    Can they communicate?
    Problem Solver:
  • 3 Answers
Basically every Polycom is fine - as long as software is a current release!
Posted on Feb 19, 2009
What model Sony camera
Polycom should be able to tell you which Sony cameras are used in the system and they may be able to suggest equivalent replacements
May 11, 2013 | Polycom Vs4000 Video Conferencing System...
Trying to install a polycom viavideo camera, my windows 7 is nor recognizing it. Where can i download the driver for ir?
The download for the Via Video II is located at the link below. Unfortunately it may not be compatible with Windows 7 as it has been discontinued and is no longer supported by Polycom.
http://downloads.polycom.com/video/viavideo/ViaVideo_5_1_1.exe
Jan 23, 2010 | Polycom ViaVideo II Webcam
Polycom SE225: my verizon line provide caller id does not displa
Due to the age of the SoundPoint Pro, it some of its features are not compatible with newer phonesystems, such as CableVision. There are no software updates for the SoundPoint Pro, and as long as the Caller ID is enabled there are no other settings or adjustments that can be made to workaround these kind of problems unfortunately. I recommend contacting your service provider to see what kind of caller ID signaling they are using; most likely they will be using a newer digital system, or MDMF which is not backwards compatible with SDMF or earlier CID receivers.
Dec 05, 2009 | Polycom SoundPoint IP 501 IP Phone
LAN Error in Sony PCS-1 Video Conference
Sounds like you are either working on a network which must provide you with an IP address automatically (i.e. not permitting static entries), or you are incorrectly configuring the information for your static address.
Is there a requirement to use a static address, or will DHCP work just fine?
Jul 10, 2009 | Sony PCS-1 (PCS1) Video Conference
DCR-TRV19 compatible with an apple computer?
Hi heather719,
Unfortunately, the DCR-TRV19 is only compatible with windows - see the list of compatible versions at this address:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV19
The only compatibility it has with Macs (and it doesn't always work) is to view still images via USB cable. In order to do this, you must manually install the required drivers from the software CD on your Mac. See the user's manual for instructions on how to do this:
http://www.docs.sony.com/release/DCRTRV19.pdf
The reason the video playback is not compatible with Macs is that you have to use an iLink cable, which is Sony's version of an IEEE 1394 ("Firewire") cable, and the iLink is only compatible with PCs (since that's what Sony makes).
If you want to get content from the tape in your camera onto a Mac, you must either:
1) Load it onto a PC, save it to a portable memory device, and transfer it, or...
2) Connect a MiniDV deck to your Mac, take the tape out of your camera, and put in the deck (like a VCR).
I'm sorry I can't give you better news - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 05, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
Connecting a polycom
No, i don't think si. The polycom needs an ethernet connection to a router. You might get this working by putting the 3g card into a PC and enabling connection sharing, however even if you got it work itsd a bad solution in terms of:
- Cost
- Reliability
- Security.
ADSL would be better.
Jun 18, 2008 | Polycom ViewStation ISDN (pcy220011323001)...
PCS-1
Reset password sony pcs-1
1. Access the Setup menu as follows:
Press and hold the MENU button on the remote commander.
2. Select Dial using the �� button on the remote commander.
3. Access the Service menu as follows:
Press 7 then 2 on the remote commander (without pressing the
PUSH ENTER button).
The Service menu appears. (See Figure 1.)
NOTE: To cancel Service mode and return to the Setup menu,
select Cancel using the arrow buttons, and press RETURN.
Jan 18, 2008 | Sony PCS-1 (PCS1) Video Conference
check for your lan settings, try to see if there is no nat on one of your network make the nat settings
Jan 11, 2008 | Sony PCS-1 (PCS1) Video Conference
Need advice on installing a Polycom 'Polyscan' video teleconferencing system
Some ideas based on your post/description:
It is very possible that the management/support software necessary to run your videoconferencing system resides or is installed in the PC based router that got burned. When you replaced the router with a NetGear, you simply provided an interconnection/distribution/forwarding/sharing of your Internet access to the different PCs of your firm but nothing to replace the server/management software for the Polyscan System. You have replaced only half of the PC based router - the router only, hence you have Internet acces but no video conferencing which is software managed which was installed in the PC half. Additionally, Polycom uses online Product Activation which might be necessary for your system to start working again.
Depending on the model of the Polyscan System that you have, it is also possible that you simply have to reconfigure the network settings of your Polyscan' System to match the new IP address of the Netgear (which might be very different from what the burned PC based router was using before). I understand that Polycom have several models (or series as they term it - PVX, TPX, RPX, VSX, HDX, and others). Would you pls post back with the series/model number that you are using?
Have you tried discussing your concern with Polycom Support? They might be in a better position to address this.
Hope this be of some help/idea. Pls post back with the Polycom system model that you are using.
Good luck and kind regards.
Nov 28, 2007 | Polycom (2200-30169-001) Router
Sony PCS-1 (PCS1) Video Conference Logo
452 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
