My printer (Lexmark X3480) keeps displaying cover open after I had inserted a new cartridge.
Open the printer and remove the grey cover. In the back there is a green printed circuit board. On the back of that the is a small black switch. A white lever is supposed to be attached here, but it always falls off. If you can find the lever, put it back on, or else, find a small piece of plastic or wood or something and duct tape it so that the switch is always in. Problem solved.
For pictures, go here:
http://www.fixya.com/support/t217347-lexmark_x3480_printer
Posted on Jan 22, 2009
Cartridges error on a lexmark
Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
Solution
One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
Turn the printer off. Doing this will disengage the cover open sensor.
With the printer switched off, open the top lid and remove the old toner cartridge.
Now replace the old cartridge with another new Lexmark toner cartridge.
Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
OR
1 Switch on the Lexmark X83 printer.
2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
6 Repeat each step in this procedure again. Close the cartridge door.
Oct 04, 2012 | Office Equipment & Supplies
The cartridge keeps going backwards and forwards and very noisy
It could be due to the encoder strip (transparent strip found behind the cartridge carrier - responsible for the movement of the cartridge carrier along its assembly) not seated properly. Try to open the printer cover and access the cartridge area. Make sure the encoder strip is not loose and still in its proper place.
Should you need further assistance, please contact Lexmark Technical Support Center for additional help.
Mar 14, 2012 | Lexmark X3480 All-In-One Printer
Hi Just wonder if you could help me i have a lexmark x3480 it has suddenly decided to display cover open and is not switching off at the control panel. The cover is not open and sits flush what is it...
It could either be due to a stuck cover sensor or the cartridges in your printer. Please follow the steps below to fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Rebrick (pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark X3480 All-In-One Printer
Hi, my printer keeps saying cover open even though it is not have opened printer up but do not know which way back to put the white piece thanks
Remove the sheets of paper. Open the printer cover and remove the cartridges as well. Close the cover. Then unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reinsert the cartridges when prompted. Load some paper. Check for any error. Try to print.
Apr 11, 2011 | Lexmark X3480 All-In-One Printer
After changing cartridge the message "cover open"
raise the cover and see if u can see a switch of some kind puss it down and see if it will print or restart ur computer and see what happens
Jan 23, 2011 | Lexmark X3480 All-In-One Printer
I changed my ink cartridge, and now it has cover open displayed but the cover is closed
when you open the lid there is a small white piece of plastic witch should be attached to a very small micro switch .this keeps coming off for some reason .you have to find it and reattach it to the switch that is just right of the middle of your printer .hope this helps
Oct 02, 2010 | Lexmark X3480 All-In-One Printer
Lexmark x3480 cartrige incorrect message
I had the same problem. Downloading and running the patch program solved it for me. Follow the link below!
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:570:0:0&docid=ENUS25374
Regards Robin
Oct 31, 2008 | Lexmark X3480 All-In-One Printer
"cover open" messagge when cover is closed
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located
Sep 16, 2008 | Lexmark X3480 All-In-One Printer
Cover open message
Jul 20, 2008 | Lexmark X3480 All-In-One Printer
X3480 cover open message
Ajkill is right, although his description isn`t very exact. Take off the complete scanner part: (back hinges first, then the blue arresting lever at the front), disconnect the flat band cable and the power supply for the scanner part and take off the complete scanner part. You´ll see a triangular part that goes in a slot of the dark grey cover which covers the rest. It should press againt a white lever which itself presses a little black switch sitting on the printed circuit board. If this white lever has fallen off the switch is always in "Cover open" position. To get it and reposition it (if it isn`t broken) you have to take off the dark grey cover which covers all the rest: take off the front screws and carefully lever out the sides with a small screw driver. Good luck with the repositioning, it is very fiddely and to see how and where it has to go you best use a magnifying glass!  But I could manage it and my printer is working now again. And good luck with fitting it all together again without breaking anything!
Mar 19, 2008 | Lexmark X3480 All-In-One Printer
73 people viewed this question
jasbo
jasbo
