Electrolux 24 in. ESI6220X Free-standing Dishwasher
Problem for Electrolux 24 in. ESI6220X Free-standing Dishwasher
Have a trouble: dish-washer will not drain.
By zheka on Mar 21, 2007
Model: electrolux ESF 6162
It seems there is a problem with draining in my dish-washer. As a result it does not work. I can choose a washing program and start it, but it does not start washing. Instead it looks like the maschine attempts to drain the water from the dishwasher and cannot do it. As a result approximately in 5 minutes the dishwasher starts showing a flashing indicator light as described below.
According to dishwasher's instruction book, if there is a continous flashing of the indicator light of the running programme and in the digital display appears .20 it means that the dishwasher will not drain.
The instruction book says that two causes are possible. One is that the sink spigot is blocked. Another is that the water drain hose has not been correctly laid or it is bent or squashed.
I checked the sink spigot and it seems it is ok.
Checked the water drain hose connection and again it seems to be ok.
And the problem persists...
Just in case here is additional information: we use the dishwasher for 1.5 years. We only cleaned the filters several times. May be some other maintanance works must have been performed...
I would appreciate any advice very much.
Thank you.
Comments:
Mar 22, 2007
- Thank you for your advice. I cannot blow through the drain hose, so it is not free. But I do not know what to do with it. Could you advise what can be done?
Mar 25, 2007
- It seems to me the drain hose cannot be removed at the dishwasher's end. At least I do not see how to remove it. Could you help on how to do that?
I think that the problem is not in the hose. But I believe the problem is inside the dish washer.
Moreover it seems now that when I start a program the dishwasher no longer attempts to drain water. Could it imply that there is a problem with the engine (is it a pump?) that performs this draining function? E.g. it is broken.
Mar 26, 2007
- it is just 1.5 years old.
Initially I could hear a noise like you describe but now only if I have my ear just at the appliance's surface.
If there is a foreign object in pump then how to remove it?
Thanks
May 09, 2008
- The problem was with its electronics. eventually I called service and they tried to change the pump engine -- but it still did not work. Finally, they had to replace the whole electronic plate -- to have it work again.
The most probable source of breakdown of electronics was insects -- there were some traces of them. So be aware -- if there are any iinsects in your area...
Thanks for all your comments and help... it is a valuable website...
Best Solution
posted on Mar 21, 2007
Helpful)
tresilla
Rank: Guru
Rating: 87%, 1597 votes
bear in mind first program action is drain but at this point there should be only a small amount of liquid in machine.check spigot is free by pouring a little water down it. blow thro drain hose to check free as well - you can get a fat blockage in drain hose. if both are free you may have a blockage in exit to pump.the only other maintenaince is to use a dishwasher 2-3 times a year
Comments:
Mar 22, 2007
- that should have been use a dishwasher cleaner 2-3 times a year
Mar 22, 2007
- when you say you can not blow thro drain hose, remember you must remove it at appliance end as there may be a 1-way valve after the pump to prevent syphoning. if after removing drain hose you find it blocked, just poke something thro it. as another test, pour a little liquid into dishwasher and check if pump removes it.
Mar 26, 2007
- when it is on drain, listen carefully for a low humming noise (not very loud) if you can hear it, then there is a foreign object in pump
how old is this appliance?
Was this helpful?
Yes
No
Solution #2
posted on May 09, 2008
Somewhat Helpful)
frankii
Rank: Apprentice
Rating: 76%, 2 votes
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Electrolux 24 in. ESI6220X
Questions and Unsolved Problems for Electrolux 24 in. ESI6220X
Do you recommend Electrolux 24 in. ESI6220X Free-standing Dishwasher?
Answer
Answer
compartment for washing tablets does not open if the tablet is released it does not melt
Answer
The lights are on the dishwasher but it does not start.
Answer
i turn it on all i get is 2 lights on eco and fast mine is a hotpoint fdw60
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Electrolux 24 in. ESI6220X...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
