Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
NEW DISHWASHER REPEATS THE WASH CYCLE FOR OVER AN HOUR 7 HALF
7:3O AM I TURN ON THE DISHWASHER; 8:45 AM STILL REPEATING THE WASH CYCLE?
  • ajfogey Mar 09, 2009
    Same as yours. It stays on the wash cycle and it is brand new.
  • santaana Apr 11, 2009
    My new dishwasher is repeated the wash cycle over 3 hours and it is still running when i send this prolem.
  • 36 Answers
Dear Customer
please perform the follownig checks
please rate this,thank u.
Posted on Dec 16, 2008
Dishwasher shuts off during cycle
Since the troubleshooting and repair process is too lengthy to include here, please go to the following link: http://www.appliance411.com/service/repairmanual.shtml
to open [or download] the service / repair manual. It is free.
Scroll about half way down the page, in the left column, under Maytag products, select the Maytag / Jenn Air / Jet Clean II "Tall Tub" Dishwasher repair manual... it covers your model dishwasher..
It includes a troubleshooting guide as well repairing instructions
Best wishes on your project.
Dec 01, 2013 | Maytag MDB9600A Jetclean II Built-in...
Model FDB1100.......brand new Dishwasher stays in wash cycle for hour and a half........any suggestions??
Hello, Thank You for using FixYa. I will be helping you today.This is normal for new dishwashers to run this long. Heavy duty cycles with options selected can run well over two hours. Your machine is ok..This is our number one service call for new dishwashers. One hour to an hour and a half if average.
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher is locked out. Clean light flashes 7
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Kenmore 17024 Built-in Dishwasher
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
Stopped runing
If you Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher blinks 7 times and then repeats, indicates a problem in the dishwasher which should be investigated and not just the control 'reset'! That is why the control will not let the dishwasher start once such a condition is detected.
If the dishwasher's electronic control doesn't detect a water temperature increase during the main wash cycle, that symptom can occur. No water temperature increase could be caused by a problem in the heater element, its in-line thermostat, the related wiring or a problem in the electronic control.
It is also possible just the washer not spraying properly (possibly from blockage in the filter or problem in the pump), the dishwasher not filling sufficiently or draining prematurely or even a problem in the door latching mechanism's switch(es) could cause it.
Feb 22, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Du1100xtpq7 has had the touch pad replaced along with the circuit board that goes behind it and yet it just keeps repeating the wash cycle and goes for hours
i would guess that you are having a problem with the optical sensor inside the pump housing. it is suppose to sense when the water is clean or dirty and allow the unit to continue washing or advance to the next cycle.
i have seen these test good but be just out of calibration enough to cause long run times.
you can try to change it yourself or have the service company try that instead of a new board and panel.
Jan 07, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
Clean light flashes cant get to start a wash cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It's not as common but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 07, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
What is the amount of time for a regular wash? Time on the plus wash?
a regular wash should take about an hour and a half. plus wash would be longer only because it heats the wash temp hotter.
wash temp is generally around 140 degrees
and your rinse is around 161 degrees.
your flow through heat assembly heats the water at 2 degrees a minute. so it can take anywhere from and hour and a half to two hours for a full cycle.
try turning your sink on hot water until you feel hot water coming out then start the dishwasher so it doesnt have to heat cold water up to those temps. it should run a little shorter.
Feb 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
452 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
