Question about Mitel 5220 IP Phone
I just got a new power supply device and am trying to reconnect my phone...the electric connection works okay, but I get a message saying "no carrrier detected" -- I probably have not connected the usb cables correctly. can you help me?
Connect it to the 3300 icp
Posted on Mar 26, 2009
What to do when your monater says no signal analog
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd and floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
Check your RAM.
The RAM is located in the middle of the motherboard.
There are tabs that you can push to release the RAM.
Remove it and put it back in place until the tabs pop out.
Loose RAM can cause your computer not to start properly where you want to see a video signal.
Make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
Restart your computer then reinstall it this should activate found new hardware wizard
Check the vga lead for secure dust free connection or try another vga lead.
also
If you have used a desktop computer or have a dual-monitor setup, you have likely seen the "No-input Signal" error message on your computer monitor.
The error message may point to a number of culprits.
Accordingly, the solutions run from simple to complex.
Prior to attempting advanced troubleshooting methods, check the connection first.
Power off the computer and the monitor.
Remove the cable that connects the monitor with the computer, then reseat it.
Try a different port, if possible, then reboot the computer.
Connect the monitor to another computer if possible to eliminate the monitor as the faulty hardware.
Shut down the computer.
Remove all cables and devices plugged into the computer.
Make a note of the port into which your monitor is plugged.
Remove the left side panel when facing the front of the case.
Unscrew screws or manipulate latches to remove the side panel.
This process varies according to the type of case you have.
Please consult your manual if you are unsure of how to remove the side panel.
Attach the antistatic wrist bracelet's clip to a metal object, then ******** the bracelet.
Locate your video card.
(This will be the card that contains the port with which your monitor interfaces.)
Remove the slot cover screw that secures the card into the slot.
Remove any power cables that connect the video card to the power supply.
Pull the card out of the slot.
Examine the gold pins to check for any damage.
Reseat the card if it physically appears to be undamaged.
You should hear a click once the card is secure in the slot.
Screw in the slot cover screw.
Attach the power cable from the power supply unit, if applicable.
Leave the case open for now.
Reconnect only the monitor, power cable and any devices required to boot the computer, then restart the computer.
Shut down the computer again if you receive the "No-input Signal" error message again.
Remove any cables and devices you plugged in to restart the machine.
Remove the video card with a spare or replacement by following the instructions above.
Connect necessary cables and devices to reboot the computer, then restart it.
Shut down the computer and remove cables and devices if the display still won't work.
Unplug the power supply's cables from all devices on the motherboard.
Make a note of each plug-in so that you can correctly connect all devices with the new power supply.
Remove the screws that mount the power supply.
Fit the new power supply into the mounting area, and screw in all screws.
Attach all required power cables to devices connected to the motherboard.
Attach the cables and devices required to start the computer.
Reboot.
http://en.allexperts.com/q/PC-hardware-CPU-1023/input-signal.htm
Jul 25, 2013 | NEC MultiSync 1770NX 17" LCD Monitor
Why does my computer say no imput signal
If you have used a desktop computer or have a dual-monitor setup, you have likely seen the "No-input Signal" error message on your computer monitor. The error message may point to a number of culprits. Accordingly, the solutions run from simple to complex. Prior to attempting advanced troubleshooting methods, check the connection first. Power off the computer and the monitor. Remove the cable that connects the monitor with the computer, then reseat it. Try a different port, if possible, then reboot the computer.
Connect the monitor to another computer if possible to eliminate the monitor as the faulty hardware. Shut down the computer. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove all cables and devices plugged into the computer. Make a note of the port into which your monitor is plugged. Remove the left side panel when facing the front of the case. Unscrew screws or manipulate latches to remove the side panel. This process varies according to the type of case you have. Please consult your manual if you are unsure of how to remove the side panel. Attach the antistatic wrist bracelet's clip to a metal object, then ******** the bracelet. Locate your video card. (This will be the card that contains the port with which your monitor interfaces.) Remove the slot cover screw that secures the card into the slot. Remove any power cables that connect the video card to the power supply. Pull the card out of the slot. Examine the gold pins to check for any damage. Reseat the card if it physically appears to be undamaged. You should hear a click once the card is secure in the slot. Screw in the slot cover screw. Attach the power cable from the power supply unit, if applicable. Leave the case open for now. Reconnect only the monitor, power cable and any devices required to boot the computer, then restart the computer. Shut down the computer again if you receive the "No-input Signal" error message again. Remove any cables and devices you plugged in to restart the machine. Remove the video card with a spare or replacement by following the instructions above. Connect necessary cables and devices to reboot the computer, then restart it. Shut down the computer and remove cables and devices if the display still won't work. Unplug the power supply's cables from all devices on the motherboard. Make a note of each plug-in so that you can correctly connect all devices with the new power supply. Remove the screws that mount the power supply. Fit the new power supply into the mounting area, and screw in all screws. Attach all required power cables to devices connected to the motherboard. Attach the cables and devices required to start the computer. Reboot. Hope this helps.
Dec 07, 2012 | Computers & Internet
When trying to leave a message, the system says the bank is full but the base says no messaes and I have pressed delete messages several times. This is a brand new phone. How can I clear the message...
Try resetting your base unit by holding [find hs] button while reconnecting power.
If it doesnt resolve your issue, try pressing the [find hs] button which is said in your manual..This would reset your device and restore you to normal state
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa!
Vinod Kumar J
Dec 04, 2010 | Uniden Cordless Phone
When I turned on my printer today all the lights on the front started flashing and this error message showed: "C4EB8000. Turn power off then on again." I've tried googling it and nothing seems...
Follow these steps to resolve the error message. It might not be necessary to complete each step to fix the issue. Step one: Disconnect all data cables and devices from the HP product
  1. Disconnect any USB, Ethernet, or parallel cables from the back of the HP product.
    CAUTION: Do not disconnect the power cord during this step. Figure 1: USB connectionc01661620.gif Figure 2: Parallel connectionc01369986.jpg
  2. Remove any memory cards or USB drives from the HP product.
Step two: Turn the HP product off and then on
  1. Press the Power button (c01602202.gif ) to turn off the HP product.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn on the HP product.
Step three: Reconnect the data cables and devices
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Reconnect one USB, Ethernet, or parallel cable to the back of the product.
  3. Press the Power button (c01602202.gif ) to turn on the product.
  4. Check the display for the error message.
    • If the error message does not display , reconnect another cable, and then repeat steps 2 through 4.
    • If the error message displays , replace the cable you just reconnected with a new one. Go to the How to Buy HP page to buy the replacement power supply for your product.
Step four: Determine if the HP product uses a power cable or a power module as the power supply If the power supply is a cable with electrical connections at each end, the product uses a power cable . Figure 3: Power cablec01369983.jpg If the power supply is a cable connected to a module or box, the product uses a power module . The power module might have a permanently attached power cord, or the power cord might detach from the power module. The term power module refers to both the power module and the power cord. Figure 4: Power modulec01369984.gif c02020663.gifIMPORTANT If the product uses a power module, make sure that the power module part number is the same as the part number listed in the User Guide to ensure you have the correct power module. If the part numbers do not match, replace the power module. Go to the How to Buy HP page to purchase the replacement power module for your product. Step five: Check the electrical connections and outlet
  1. Disconnect the power cable or power module from the back of the product.
  2. Disconnect the power cable or power module from any power strips or surge protectors.
    NOTE: If the product uses a power module with a detachable power cord, unplug the cord from the power module, and then plug it into the power module again.
  3. Wait 30 seconds
  4. Plug the power cable or power module directly into a wall outlet.
  5. Reconnect the power cable or power module to the back of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
  7. Monitor the product to see if it turns on then off again.
    • If the product remains on , you might have too many devices plugged into the power strip or surge protector. You might also need a new one.
    • If the product turns off , the source of the problem is the electrical outlet. Continue to the next step.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Nov 11, 2010 | HP Photosmart C5280 Printer
Dell dimension 3000 showing the following LEDS on the back a-green, b-yellow, c-yellow, d-yellow, won't boot up.
if the Dell logo does not appear at all when you start the computer, unplug its power cord, press its power button for say 10 seconds to clear any power left to it. Next, try to disconnect all external devices connected to it, then remove the power and ide/sata cables to your hard drive and/or CD/DVD drives, remove all the memory and just reconnect 1 confimed working memory to the first memor slot. Remove any other cards like video card, or network cards, then remove and reconnect the power connection from the power supply to the motherboard. Reconnect the power cable and attempt to turn it on. If the back panel light code changes, try to re-connect the devices starting from the memory, then expansion cards and the storage devices one by one. After connecting each card or device, test the system to see which device may be at fault. If nothing changes, could be your power supply or mainboard and you may need to get the replacement for them. HOpe this lead you to the right direction in getting this solved. feel free to rate how helpful this information is. Thanks
Oct 14, 2010 | Dell Dimension 3000 PC Desktop
Phone won't work
try unplugging the base and plugging it back in. Or try a different outlet for the base.
Jun 10, 2010 | Panasonic KX-TG1033S Cordless Phone
Set up NPS
while installing setup for samsnung mobile..a message appeared "NPS not exist "..wat do i do??
Aug 27, 2009 | Dell 210W Optiplex GX270 NPS-210 AB Power...
Cant listen to music on ipod touch because its disabled
force it into recovery mode...here's how
  1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
  2. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  4. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.ht1808_01.jpg
  5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  6. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
    ht1808_02.jpgIf you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Aug 10, 2009 | Apple iPod touch
Carriage jam
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Nov 11, 2008 | HP Photosmart C4280 Aio Printer
Mitel 5220 IP Phone Logo
111 people viewed this question
Top Mitel Computers & Internet Experts
Marvin
Marvin
Gil Shultz
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
