Question about Hotpoint First Edition WMA12 Front Load Washer
No instructions i have a Hotpoint First Edition 1000 spin few 10 washing machine,i need instructions or close up picture of the dials as they are faded.
  • doscott Jan 04, 2009
    i have the same washing machine and all the numbers have come off so i dont know what wash to put things on
  • Hotpoint Master
  • 3,463 Answers
Go to:
www.hotoint.co.uk.
Scroll down and click on www.hotpoint.co.uk.
Click on after sales and then click on down load instruction books, type your model number in and you can save it to your hard drive, or print it off.
Plz rate my solution.
Thanks.
Posted on Dec 16, 2008
Where is pressure chamber bottli in hotpoint first editon 1000 wm19?
to get to it you need to remove the plug so there is no power to the machine????
take off the top
turn upside down ,
put the screws into the lid as you take them out
remove the dial screw at the back
remove soap dish.. 6 screws
unclip the door seal
take of the front 6 screws
follow the pipe from pressure switch down
there it is to take of and clean there is 3 screws
now you need a dumpy screw driver
May 18, 2014 | Hotpoint First Edition FEW12 Front Load...
My Hotpoint wf000 1000 spin model won't spin. It goes through a full wash cycle, agitates fine, but just won't spin at the end of the wash. Any help appreciated.
Sorry if it may be too obvious, but have you checked the philtre? generally they stop spinning when it's stuffed... when you open it, make sure you have a mop and bucket handy, some water will come out!
Nov 06, 2012 | Washing Machines
HOTPOINT FIRST EDITION 800 WM51 USER MANUAL?
my hotpoint first edition 800 wm51 wont spin?
Nov 17, 2010 | Washing Machines
Hotpoint first edition automatic washing machine washes clothes .
I've got a Hotpoint First Edition WM52 that stopped spinning at the end of the wash cycle. Called the repair man and he said it was most likely just the filter blocked? Suggested I reemove the front base panel and try to locate the filter remove, clean and replace. Front panel wouldn't come off, base panel at the rear, 6 screws to remove revealing a black squeezy hose with slide grips holding them on, on removal of the hose two ten pence pieces, a one pence piece and a childs hair clip blackened with dirt sat blocking the top of the hose.
Hope this helps; repair man saved me £58+vat just with a few words and a bit of persistence from myself
Jun 17, 2009 | Hotpoint First Edition FEW10P Front Load...
Dial won't move automatically
The dial is not a timer that moves through the prog, it is a selector switch, which selects the programme you require, and therefore does not move round
You need to check the filter re the spin prob.
Remove rear panel, remove large black hose from bottom of tub, remove filter, and clean.
Refit filter and hose.
Test for leaks
Thanks
Jan 11, 2009 | Hotpoint First Edition WMA20 Front Load...
Washing machine not spinning at the end of cycle
if the dial is moving round as normal and the machine is filling and emptyin change the motor brushes this will cure the problem
Dec 20, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint FEW 12 filling problem
possibly overfilling, or blockge in dispenser or hose from dispenser to drum.
Oct 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Not draining and flooding my kitchen!
hiya
first off norah, you will need to check the pump filter as there is probably a blockage in there.
secondly guest, sounds like a faulty pressure switch or even a small hole in the pressure pipe, thats why your machine will not stop filling.
hope these help
please dont forget to rate the helpfulness of this reply thanks kj
Jun 09, 2008 | Hotpoint First Edition FEW12 Front Load...
The water will not drain on my first edition wma 10 hotpoint washing machine so does not spin either any clues to where the filter is???????
Most likely something stuck in the pump. Remove front panel and hose that goes into pump. usually you will see the object. if not remove pump and look inside.
Jan 06, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint First Edition WMA12 Front Load Washer Logo
321 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
