SOURCE: IBM thinkpad T21
I had a similar problem after My pc got damp in a bag in the rain. I contacted IBM and was given this fix which I am supprised worked but it did so here it is cannot hurt to try. Remove the main battery and the mains power supply press the power on button for 17 seconds. This I think is to drain all the power from the laptop altogether. Replace the mains lead and turn on. Once the laptop has openen up into windows turn it off and replace the mains battery then power on again. In my case this worked I hope this helps.
SOURCE: My IBM R51 2887 model LCD Screen Problem
Here you can get the replacement LCD panel and change it yourself:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
SOURCE: Wireless question - Thinkpad R51
Just go to the network connections and disable the wireless whenever u dont need wireless..... and check the ethernet drivers are installed or not..from device manager
U can download new version drivers from ibm site..
thanks
mohan
SOURCE: ibm think pad r51 nodisplay 4 beeps commaing
This indicates a possible memory problem. Reseat the RAM modules and boot up, if OK then the laptop is OK.
If not then :-
If you have two RAM modules, remove both and insert one and boot up, if it is OK then repeat with the other one - this will determine which memory module is faulty.
SOURCE: IBM THINKPAD AUDIO DRIVER
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model laptop,
Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
