Question about Pentax Optio S50 Digital Camera
S40 Battery problem
Reaplaced my dead rechargeable batteries with new alkaline AA's and the camera won't work - still shows "battery depleted". These new batteries work in my daughters camera so they are not the problem. I tried some NIMH batteries and they work in my camera. Why won't my camera accept the akaline batteries ?
  • Anonymous Jan 23, 2008
    Pebtax Option S50 - Battery Depleted Error message - I use re-chargable batteries which work in other cameras. After charging for 12 hours it still says battery depleted. Can it be anything else?
    Mich Cape Town
  • Anonymous Apr 27, 2008
    This is not exclusively a battery problem and may be related in some cases to a firmware bug in the camera. In some circumstances you can get the same error if youdownload images vis the USB lead and don't disconnet in the right way. Sometimes reconnecting the camera clears the problem and sometimes it doesn't.
    Novelist:
  • 107 Answers
Alkaline batteries are not capable of outputting the level of power required for your camera to operate. Your daughter's camera may have lower requirements and be able to function properly using alkaline batteries. Your standard alkaline battery outputs about 700 milliamps of power when they are brand new. A rechargeable NiMH battery can range from 1200 to 2700 or even 3200 milliamps max power output depending on the quality of the battery. Most compact digital cameras that accept AA style batteries are designed for these high-output rechargeables and will not function for very long even on fresh Alkaline batteries. David Millier Advance Camera Repair
Posted on Mar 23, 2007
This camera is also able to use CRV3's. Some brands of the rechargeable version have a slightly power output than the disposable and work well when alkalines and NiMHs don't.
Posted on Jul 03, 2007
On?Off switch failure
Not sure the A3300 has two AA sized batteries, but if it had:
Sure your batteries are still tip top?
Try two new AA sized NiMH rechargeable batteries or if you have some new alkaline batteries, put them in. the alkaline batteries won't last long, but it it could hint if the camera is still working and worth buying new rechargeables.
AA manganese (Zinc-Carbon) batteries cannot be used with this camera.
But even if it has one battery, check the battery.
Read other parts about batteries, in other help text I wrote for other users.
Nov 27, 2013 | Canon A3300 IS Digital Camera
Is it necessary to use Kodak AA alkaline batteries in the camera or will other AA alkalines work?
Other battery will work in your camera as long as it is AA alkaline.
You can also use rechargeable battery with different brand.
Apr 13, 2010 | Kodak EasyShare Z915 Digital Camera
I keep getting a battery depleted message
I don't know but that would be wierd if this was Paula Meadows from McAlester
Sep 08, 2009 | Pentax K100D Digital Camera
Battery depleted
Sounds like the battery might be defective/worn out. If it's AA batteries (a.k.a. R6) try with a pair of good-quality alkaline batteries to see if it works then. Cheap batteries often doesn't have enogh "umph" to power cameras.
Dec 20, 2007 | HP Photosmart 735 Digital Camera
Batteries are Depleted
A camera rep told me that use about 2500mi (?) batteries instead of the 900 I was using otherwise the batteries will be depleted with just one picture. Digital cameras or any other digital piece of equipment needs the extra power. Make sure that your charger will charge the 2500 power ones fully.
Dec 17, 2007 | HP Photosmart M407 Digital Camera
Depleted Batteries
Clean the contacts in the battery chamber to get to the bottom of the chamber use an eraser on the end of a pencil Also the top contacts. you could also try packing out the contacts on the tops of the batteries to ensure good contact.
Sep 14, 2007 | Pentax Optio S40 Digital Camera
Choosing batteries
Your camera requires four AA size batteries.There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Choosing batteries
Your camera requires four AA size batteries. There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the Display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may vary based on the Alkaline batteries selected. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba Sora PDR-T10 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Pentax Optio S50 Digital Camera Logo
505 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
