Question about E-Machines eMachines Desktop PC
My automatic updates keeps turning itself off. i have gone to admin. tools.... tried to enable but the system won't allow it
  • 1 more comment
  • angbar1222 Dec 16, 2008
    Thanks Guru,
    I tried all that and still it is turning itself off, within a second of my turning it on. it won't even allow me to do auto updates manually.
    Help
  • angbar1222 Dec 17, 2008
    Hi Kaj,
    Yes, automatic updates did work before. I have not been connected with a buisness or other network with this computer. It is a home computer too though. I have never been conneted with a buisness.
    Thanks Ang
  • Kaj Bjorlin
    Kaj Bjorlin May 11, 2010
    Did it work before? It's most likely a SPYWARE/VIRUS that is disabeling this function (not unusual).
    Is this a HOME PC or is it connected to business network? If it's not on a business network - has it ever been?
    Please respond here so we can get this solved for you.
    Thanks,
    Kaj
  • 326 Answers
From your start menu type services.msc in the run box and press ok, look for automatic updates from the list and make sure the service is set to automatic
let me know how you get on
Posted on Dec 16, 2008
Lenovo g500 restarting itself
There is a variable (system setting) integrated into the Windows Update tab in the control panel that enables and disables notifications of automatic restart to complete the installation of system updates.
Nov 13, 2013 | Lenovo Computers & Internet
S20113 neo driver
If you're using WIN XP as your OS,this tool may help.
DRIVER ROBOT
KEY : JCCQ-MAKC-KACK-6TSE-BN35
Driver Robot updates:
* Sound card drivers
* Printer drivers
* Video card drivers
* Motherboard drivers
* Webcam drivers
* Wireless drivers
* Bluetooth drivers
* FireWire drivers
* Ethernet drivers
* Windows XP drivers
* Windows Vista drivers
* USB drivers
* Chipset drivers
* AC97 drivers
* DVD drivers
* Router drivers
Enjoy...
Jun 28, 2011 | Computers & Internet
Sir windows could not search for new updates error found: Code80072EFE I'm using windows vista ultimate can you help me Sir?
Check your services, in admin options make sure automatic updates are turned on if not click the start button next to windows update and select enable on the drop down menu.
Jun 02, 2011 | Microsoft Windows Vista Ultimate Edition
When I try o oen a folder on my documents it throws up ,cookies must be enabled I keep trying to find solutions but to no avail
HELLO, I am Lucky4lynn2 and I will walk you through it ok?
1) Open your Internet Browser.
2) Click on TOOLS / INTERNET OPTIONS / PRIVACY / ADVANCED / Make Checks in the following: a) Override automatic cookie handling. b) Allow & Allow c) Always allow session cookies.
Press OK.
3) RESTART YOUR BROWSER
THAT SHOULD DO IT!! GOOD LUCK!!
Mar 26, 2010 | Acer Aspire 5735-6694 Notebook
After getting windows updates, the laptop gets to stage 3 of 3 and keeps resetting itself, I can't load windows because whenever I do it automatically tries to complete the update, resets and repeats! The...
Start your system by pressing F8 during startup;Select "last know good configuration that works",It will most probably solve your problem.
If above thing doesn't work,repeat the same step by selecting "safe boot" and follow the instruction below
To remove Windows updates, there are two ways to do this:
1) Add / Remove Programs: Use the Add / Remove Programs tool in the Control Panel to remove the updates. Open it, and make sure the “Show Updates” box is checked (it’s located in the upper right of the tool). Scan through the list and see if you can find the updates you’ve mentioned below. Remove them if you see them. Reboot and see if you still have the problem. If you don’t find the updates listed here, you’ll have to use the second option below.
2) In your Windows XP Start Menu, go to All Programs, point to Accessories, point to System Tools, and then click System Restore. The System Restore tool will start. Use that to restore your PC to a previous date – you should be able to select to restore to a time before those updates were installed. The tool will allow you to pick from certain times you can restore to. Pick the date and time that’s just before you installed the updates.
If neither of these fix the issue or remove the updates, then the problem is not something I can easily troubleshoot over email. There may be anything from hardware problems to network problems to CPU and process problems. To continue the troubleshooting, you’d be best off showing your PC to a local computer geek.
If removing the Windows updates fixes your problem, then we at least know the cause. If you’re really ambitious, you can reinstall those same updates one at a time to determine which one is causing the problem. At that point you can simply not install it, or keep an eye out for an update to the update!
Dec 24, 2009 | Acer Extensa 390CX Notebook
What is an ArcCon ac application error0xc00000006?
What you describe falls under the general category of svchost.exe issues. Svchost.exe is used by your computer to access the registry and check the services to load during system startup.
arccon.ac is an ArcSoft Connect Notifier. There are two possibilities why its happening:
  1. Microsoft releases regular security updates that are installed automatically on your computer by the Automatic Updates feature, which is enabled by default on your computer. The Svchost.exe Application error usually appears due to a problem with a recent update.
Closing the error message might freeze your computer. To fix this error, perform the following tasks.
  1. Open Control Panel, select Performance and Maintenance, and then select Services.
  2. In the System Properties dialog box, open the Automatic Updates tab.
  3. Next, select the Turn Off Automatic Updates option.
  4. Select Apply and then OK to accept your changes and exit the System Properties dialog box.
  5. Restart your PC.
  6. Ensure that you are connected to the Internet and then select the Windows Update command from Start > All Programs to manually update Windows.
  7. After the update is complete, enable the automatic updates again from System Properties > Automatic Updates.
This should rectify your application error. However, if the error keeps reappearing, then you might turn off automatic updates permanently and manually perform Windows updates at regular intervals.
Errors Caused By Virus Infection
Let's hope that this isn't the case. Lengthy procedure but if you are still having trouble, we'll cross that bridge when we get to it.
Dec 09, 2009 | Computers & Internet
After an automatic software upgrade from HP for my Photosmart c7280, the Scan feature no longer works. Get a statement saying there is no connectivity to my laptop (Dell Inspiron w/Vista. HP won't help...
If you have system restore activated on your computer it will automatically make a restore point before installing any profram or update. Go to start > programs > accessories > system tools > System Restore. Click a restore point before the time you installed the update, iy should be listed, if you have to go back a few days just to make sure. Follow the prompts and let the computer reboot, it will wind itself back to the day it ran fine. Just make sure to not allow the printer to update that file again.
Sep 07, 2009 | Office Equipment & Supplies
My system is turned on autoatically it goes to
You must have enabled a software to turn on your pc at a particular time or after a particular interval to check for the updates. Check your antivirus autoupdate make it manual windows automatic update to manual check scheduled task and clear whatever wakes ur pc. If none of these then you shall get a good malware removal tool
Jun 13, 2009 | Microsoft Windows XP Professional for PC
My message keeps saying new flash player required but I cannot update it
click on the Tools icon in your browser... Choost Internet Options.. from there , choose the Security tab, click on the Custom button, and scroll down to the ActiveX Controls... look there for Download Signed ActiveX Controls... Choose to Prompt or Allow..( Enable)... then try messenger
Jun 09, 2008 | Toshiba Satellite P100 Notebook
Connection to ps3 drops in and out
GO to network settings...Check out Settings and Connection status list...make sure everything is enabled, wireless, and Automatic....reset your connection..and ur router....turn off the WEP ...security disable....
internet connection : Enabled
connection method : wireless
signal strenght: 100%
SSID : (name of your wireless router)
Security: i set NONE....no one really cares to hack ur PS3 ppl turn this off
Address settings : AUTOMATIC
Feb 11, 2008 | NetGear DG834G Router
E-Machines eMachines Desktop PC Logo
35 people viewed this question
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
