Question about Sharp VL-Z5 Mini DV Digital Camcorder
Cassette wont load
When i put the casette in the camcorder it wont go down/ load
    Scholar:
  • 63 Answers
First, check battery and replace if necessary or plug in to power if you have an adapter. Make sure cassette is undamaged, possibly trying another one instead. Do not force any entry. Good Luck!
Posted on Dec 16, 2008
How do i get the casette out of the canon mv700i ? i see a push button on the casette but it doesnt work.
You may need to have a charged battery pack attached to the camcorder (or use the mains power lead, if applicable), so that the camcorder has power to open the cassette door. You may even need to turn the camcorder on. These are safety refinements so that the eject button does not accidentally open the door, leading to possible loss of cassette or damage to the camcorder itself.
Jan 27, 2016 | Canon MV700i Mini DV Digital Camcorder
Cassette wont go down
This can be due to many faults and need a full check up but I can fill up with few tips.
1. If the cassette does not loads it is a fault on the loading mechanism as once the cassette is put into the hodler and pressed down the load motor must take up to forward the mechansim and mode..
2. Defective loading motor, loading drive mechanism or carriage alignment.
3. Fault in the power section to deliver the correct voltage to the circuits/loading servo to take up.
4 Finally if the loading is not to the MODE switch point or failure of mode can make the loading to trip as it will not complete the load to the desired point.
Jul 23, 2011 | Canon DM-XM2 Mini DV Digital Camcorder
When i insert the Sony Cassette i get the message Reinsert the cassette what can i do
there is a caasette called cleaning casette in the the shop itself
oyu can get it from the shop itself
its the same as the cassette
Dec 13, 2010 | Sony DCR-HC19E Mini DV Digital Camcorder
Will not rewind
Sony is pretty secretive about the :23 code. It can't be found anywhere. However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Sep 28, 2009 | Video Cameras
Remove tape error message
I used my hairdryer to blow dust out of the cassette compartment. It worked for me.
May 05, 2009 | Canon Optura 20 Mini DV Digital Camcorder
Will not accept cassette - keeps responding "eject cassette"
Had the same problem and took the battery out of the camera to reset. Worked fine after that.
Mar 28, 2009 | Canon ZR300 Mini DV Digital Camcorder
Casette
You could have one of several problems. The cleaning message comes up when the camcorder cannot read the signal from the tape properly. This can be caused by:
1) A dirty video head
2) the tape guides being out of alignment
3) A worn or broken video head
If a cleaning cassette head does not help, you will need a tech to look at it.
Oct 18, 2008 | JVC GR-D90U Camcorder
Recording stopped working
Beleive the CCD has stopped responding. A cheap way to verify this is to point an infrared remote towards the lens and press a key. This will usually provoke a response from the camera even if all else fails, barring a bad pickup device...accordianman
Apr 26, 2008 | Canon ZR200 Mini DV Digital Camcorder
Cassette holder does not close
Try inserting another tape first. If the trouble is still there,Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Aug 20, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp VL-Z5 Mini DV Digital Camcorder Logo
101 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
