Question about GE JE1860 Microwave Oven
GE JE1860 Microwave is not heating
I bought a GE JE1860 Microwave in June 2007. This morning it has stopped heating/cooking. Everything else is working. There is a "hum" from the microwave that wasn't there before. Also, a small picture of a microwave oven has appeared on the display panel. Help.
  • GE Master
  • 19,396 Answers
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
Everything works except that I can heat anything.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 12, 2011 | GE JE1860 Microwave Oven
Have ge model je1860 turns on but when you hit cook nothing happens is it the turn table motor. i don't want to do trial and error on parts.naturally the fuse is good
I'll presume you can program it ( set the length of time you want to cook)
Does the timer count down?
Does the turntable ( if you have one) turn?
If everything else seems to work properly and it just doesn't cook more then likely the magnetron is bad
$87 from Sears:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JE1860WH04/0432/0123245/G0590488/00005?blt=06&prst=&shdMod=
Jan 18, 2011 | GE JE1860 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
How do I replace the magnetron in my GE JE1860?
Considering the cost to have the microwave repaired: both labor and parts, it is more economical to purchase a new one unless it is still under warranty.
Jan 01, 2009 | GE JE1860 Microwave Oven
GE Microwave Model # JE1860: Unit does not heat. The timer counts down, but the oven does not heat.
When you hit Start to cook, do the inside light, cooling fan, and turntable come on?
Any unusual noises? Is it louder or quieter than usual?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Nov 27, 2008 | Microwave Ovens
Microwave not working
faulty relay or solder joint on the power module, but a bad door switch is most common.
Nov 13, 2008 | GE JE1860 Microwave Oven
GE # JE 1860WH AH900849 not heating
hi Kathrine,
It sounds like the magnetron may be bad, if this is the case it may still be under warranty. Check to see if it's in warranty if it is contact GE or the store you bought it from. If it is I would not recommend you repair yourself (very dangerous voltage, and a very expensive part)
Mar 21, 2008 | GE JE1860 Microwave Oven
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
GE JE1860 Microwave Oven Logo
313 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
