Question about Logitech Squeezebox Duet
Wharfedale TU160DTR saying fail
Our wharfedale TU160DTR was working ok, if skipping a few recordings up until a day or 2 ago when it wouldn't turn on and came up with a message saying fail. i'm assuming this is probably terminal but we live on Lundy Island so returning it won't be easy. any ideas?
  • wendy_kidd2 Mar 26, 2009
    Exact same problem, Fail is shown on display window. Have tried unplugging to reboot. This Freeview box has been one problem after an other........ DO NOT BUY ONE!!!!!!!!!!!!!
  • morse564 May 05, 2009
    Box working fine - had a problem getting access to recorded items then FAIL appeared on the display window. Now can do nothing with it. Very poor considering only 6 months old. Have notices same box now being marketed as a BUSH by ARGOS.
Wharfedale tu160dtr
run a sceen on the hard drive to se if it bad
Nov 19, 2013 | Televison & Video
The recorder won't respond to the remote and I can't change channels or access anything with remote. Mislaid the instructions which give details to fix this. Wharfedale TU160DTR Here's hoping someone can...
Try this. Open up your pc cam then point the remote straight at the cam. You should see pulsating light on the computer screen as you look at the cams video. This tells you ar least that the remote is working fine.
Jul 03, 2010 | Televison & Video
User Manual Wharfedale TU160DTR
go to
http://www.sharpelectronics.info/Manuals.aspx
select TUR160HA and click search
this is not exact model, but similar in most functions
Sep 11, 2009 | Televison & Video
Disc tray won't stay closed.
I fixed this by jerking the tray gently. Someone jammed my tray and it skipped a few gear teeth. It seemed like the machine couldn't pull it in far enough to reach its preset position. So I let it close and when it was almost closed, I gently jerked it out to skip the gear teeth back into alignment. It is kind of tricky because the motor will just reverse instead of skipping teeth (you'll hear the plastic clicking when it skips). Perhaps unplug it and slowly push it in manually then **** it back out softly. Just be gentle. Good luck.
May 16, 2009 | Pioneer Televison & Video
How to get a message on a telstra m450 answering machine
To change the answer message, hold ans on/off then HOLD the skip back button, don't let go until you finish the message, to change the amount of calls untill it plays the answer machine hold skip forward button till it says how many the press the forward button till you are happy, to change date and time, hold stop, it will say the day to change press skip forward, then press stop again, it will say the hour, press skip forward, then stop the minute, then skip forward, then stop again to confirm, i belive it is in 24hour time as well, when changing the time, but not on playback.
Hope this helps
Feb 08, 2009 | Lands Phones
Wharfedale DTR
I've just bought the same dtr myself, and it had no problems scanning the channels, the other solution is to register a topuptv card that you had supplied with the box, put it in the box with the pin side facing up on channel 5 for an hour, take the card out then re-insert it the same way then after upto four hours setanta should appear, aswell as the other channels, they work perfectly on mine, much better than the thomson ones ever did, le us know how you get on with it
Sep 14, 2008 | Televison & Video
My stiletto records for about 18 minutes then stops
Daylight savings time change a few months ago messed up the timer recording schedule - you must now fix it. Daylight savings time changes will always mess up this recorder. You must reset your recording schedule.
For more info on fixing, go to:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1745656&catParentID=7874&scId=7874&oldParentID=&cid=SL100PK1
2 other remote possibilities:
If no signal is present at the time the recording is scheduled to start, the recording will be skipped.
Make sure you have followed all instructions on pp. 55-58
-Tha Mp3 Doctor
Jun 03, 2008 | Sirius STILETTO 100 MP3 Player
Lite On disc writing failure
try updating the rom by downloading from lite-0n
Mar 27, 2008 | Lite On LVW-5006 DVD Recorder
Logitech Squeezebox Duet Logo
676 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
