Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
My Sandisk Sansa c250 wont charge or turn on
I have a Sandisk Sansa c250 i tried to fix the promblem but not working i check the usb wire nothing wrong with it but the mp3 its self i removed the face plate were the play buttons are at i move it to a side then a lot of scrambleing came on the screen meaning it turn on but then it shut down on me and it did this twice i went to my friend cause he has the same thing so i swap the battiery from mine on to his i turn it on then it said low batt so i back check the usb and now it wont charge can it be the wire or the mp3 player itself
  • 8,596 Answers
Opening the player up was a bad idea. You probably could have run the Sansa Recovery Tool from Sandisk's website, but now you might have moved the hardware around - there is YouTube video that shows the inside of the Sansa player (several actually) that might give you some hints. But try the soft fixes first:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Music not synchronized
Try going to the actual file the music is in on your computer, then right click Send To sansa 250. If that doesn't work look on the options menu for USB mode and change it, that works on my 280.
Oct 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa clip 2 gb
My sandisk c250 will not charge on my laptop do I need software or can I download a program.When I plug in the mp3 it will not do anything.
Sep 14, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Help plz
What op system are you running?
Aug 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c250
Get a USB cord and connect it to the computer. It will automatically charge with no software installed on your computer.
Mar 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Invalid image on sansa c250
hold the record button
plug in the usb jack
release the record button
this should put it in the right mode.
then you need to reinstall the correct firmware.
since sansa doesnt post this on their website, check out the anythingbutipod forums
Feb 18, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Unable to download anything SanDisk c250
In order for you to resolve the problem you are having, you will have to update the firmware on the device...This is a common problem whenever the device firmware is corrupted...To download the device firmware you need to go to site below....
http://sandisk.com/Retail/Default.aspx?CatID=1376
And also you need to check the device USB mode under setting...It has to be under MTP mode or auto...should you need any other assistance please contact me or you can call call sandisk1.gif at 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Feb 08, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Charging
is it on or off when you plug it in? try both.
you could also try a different computer, only two of the 3 comps in my house even recognize my player.
Jan 14, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sandisk sansa c250
Have you tried the firmware update? Our C250 was useless until we updated it:
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Jan 02, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c250 not working at all!
2 Suggestions: 1) It may be that the battery isnt charged, let the unit charge fully 2) If that doesnt work, its probably time to send the unit back to sandisk
Jul 23, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
171 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
