Question about Xerox FaxCentre F12 Laser Printer
Red light on
The display says heatting error. What does it mean.
    President:
  • 2,072 Answers
That means your fuser most likely over heated, Will most likely have to be replaced.
Posted on Dec 16, 2008
I have a Fisher&Paykal DD6031 drawer dishwasher. Stopped running mid cycle. Lights flashing on drawer front green,red,yellow,red green,red,yellow . I don't know what that code means. On the inside Heavy...
follow this steps and fix it. GOD BLESS YOU
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Tip
XBox360 error codes (Three Red Lights of Death, Red Ring of Death, X-Clamp)
Hi.
XBox 360 error codes are displayed with flashing lights in the ring of bi-color LEDs located around the start button, like in the picture below:
They are often called lights of death. The technical name from Microsoft is Light codes.
LEDs located around the start button can be green or red. When they get red it means that there is a problem.
When the XBox is operating normally The leds will be green. The number of green segments indicates the number of controllers connected to the Xbox.
Here a working Xbox with one and four controllers connected to the console:
If the lights are red instead of green, then there is a problem. Here the four common error codes:
A: The code in picture A, with only one red segment on and flashing on the fourth quadrant, means that there had been an hardware failure. The internal component failing is often not specified.
The light code is accompained by an error message on display, telling a numeric code that can better address the cause of the fault. The best thing to do is contacting Microsoft to find out the reason for the code. Depending on the code you may also be asked to perform a secondary error code retrieval procedure.
In the Example above E74 means that there is an hardware fault on video connections or GPU.
B: If the first and fourth quadrant LEDs are on, that means that there had been overheating. Internal fans, CPU and board must be tested.
C: General hardware failure. This means that the console detected an internal failure, but no error code is displayed on screen. Call Microsoft to get instructions on detecting secondary code or sending the console for repair.This error code is commonly called Three Lights of Death.
D: The last error means that there is a problem with the AV connection to the monitor or TV. The code is not displayed if you use HDMI connection, in that case you get an on-screen error code. Test using different cables. If that does not fix the problem, this error means that the XBox Gpu is fried. This error code is commonly called Red Ring of Death or RROD.
In the near future I plan to publish a new article explaining how to troubleshoot secondary error codes. In the meanwhile, if you need more support, you can ask a question to our experts or contact Microsoft.
Regards.
on Apr 08, 2010 | Microsoft Xbox 360 Console
Power light is green than goes red
Hi beinhauert,
The symptoms you've mentioned indicated that the unit turned to standby mode. This is an indication that there's something wrong on the TV. To help us narrow down where the fault came from, please access the built in "Self diagnostic Screen". Follow the steps below.
In standby mode (red light is on), press the button on the remote control in sequence "Display", "5", "Volume (-)", "Power". Self diagnostic screen's displays its log of error. Please let me know the error code with corresponding numerical value "1" means error has been detected, "0" means no error.
Jdvillanueva
Jan 06, 2012 | Sony Grand WEGA KDF-60WF655 60" Rear...
My fisher & paykel smart drive excellence 7.5 washing machine squirts water in a few times and then stops and beeps and displays 3 lights red orange and (short wash) green as well as low and med speed...
Although slightly unclear these are the only possible error combinations for the leds on the machine as you look at it with red always on the end right hand side.
(11) 1011 (Green - nil - Orange - Red) - pressure problems perhaps a blockage in the tube to bowl.
(13) 1101 (Green-Orange-nil-Red) - pump is faulty
(15) 1111 (all lights on) - display module is faulty
I do not recall that the leds across the spin speed actually means something.
Good luck
Jun 06, 2011 | Fisher and Paykel Washing Machines
One red light just appears,say's system error.
1 red light is a display chip error it means that it has overheated, you can fix it by stopping the heat build up and you will be fine.
There are 2 choices for this and the first is to send it in and they will fix it for you, or you can fix it yourself using a good repair guide.
If you DO send it in for this error they will charge you for the fix.
I hope this helps you.
Apr 20, 2011 | Microsoft Xbox 360 Console
Red light problem
If you are getting the red light error this is caused by different things depending on how many red lights you having showing up:
1 red light is the display chip overheating
2 red lights is the whole console overheating and you should try and cool it down to fix this.
3 red lights is the most common error and it is caused by the GPU and the CPU overheating, you will need to stop the heat build up.
4 red lights is just the AV cable not plugged in normally.
To fix the 1, 2 , 3 red light error you will need to send it in and they will fix it for you.
The only problem is that this can take about 4 weeks and you will also have to pay out a repair fee to fix the problem.
The other way is to use a good Xbox 360 Repair guide that will show you how to stop the heat build up on the chips.
There are a few of them about but i have put together a list of the top sites HERE.
I hope this helps and if so please rate it so it can help others.
Jan 07, 2011 | Microsoft Xbox 360 Console
My xbox has the red ring of death,how do i fix it?
If you get Red Ring of Death you need to first check how may red rings are you getting and do you see any error message on screen with red ring or the console does not start at all
When there is a general hardware failure. While this can be caused by any part(or lack thereof) on the 360, the general cause is from excessive heat, which stresses the solder joints on the CPU and GPU
What Do The Red Light Errors Mean?
  • 1 light means you have had general hardware failure. If you to send it in to get it repaired, without a warranty would cost. Not to mention it can take up to a month for you to get your system back.
  • 2 lights mean your console is over heating---TURN IT OFF NOW TO AVOID SERIOUSLY DAMAGING YOUR SYSTEM!
  • 3 lights also mean general hardware failure.
  • 4 lights simply mean there is a problem with the AV cable. Check the connection and replace if necessary.
basically when you get a RRoD you can try cleaning the connection point of your AV cable but if it does not work please send it to MS Support for repairs, i had 3 Red light problem and with error message E74 i send it Microsoft Support as my console was under warranty
Nov 19, 2009 | Microsoft Xbox 360 Console
Played a new game on my xbox 360, turned it off, & when I turned it back on a red blinking light was on the power ring. Tried unplugging all accessories/hard drive, but still same result. Any...
* 1 light means you have had general hardware failure. If you to send it in to get it repaired, without a warranty would cost. Not to mention it can take up to a month for you to get your system back.
* 2 lights mean your console is over heating---TURN IT OFF NOW TO AVOID SERIOUSLY DAMAGING YOUR SYSTEM!
* 3 lights also mean general hardware failure.
* 4 lights simply mean there is a problem with the AV cable. Check the connection and replace if necessary.
Nov 14, 2009 | Microsoft Xbox 360 Console
Micro wave is not working
don't know about the red light, but (fancy this) I had the same problem with my microwave tonight. Everything but heat worked. Unplug it, plug it back in. Worked for my GE Spacemaker.
Jan 27, 2009 | Emerson Microwave Ovens
Console light it red and flashing
flashing red light usually means the display cable isnt working, otherwise it would give you an error code.
Have you tried a new display cable (thing that goes between console and tv). I'd give that a go.
Mar 31, 2008 | SNK Neo Geo Pocket Console
Xerox FaxCentre F12 Laser Printer Logo
47 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
