Question about Fargo Pro L ID Thermal Printer
When i start my computer is pops up with solution center somethin
So it says needs fixing so i found the disc that came with my printer/ camera combo and then it said :
solution center
Module
C:\Windows\System 32\Macromed\flash\flash9b.ocx
failed to register.
HRESULT-2147220473.
contact your support personnel
i dont know how to contact my personnel and i found here
my printer still works fine my computer lags and i am trying to connect with a digital photo frame and thats not working but the solution center message came on before i got the digital frame
WHAT IS GOING ON??
I have an Acer Aspire 5733z-4851.....when I turn it on it starts up then goes to a screen saying "SETUP IS STARTING SERVICES"....after a few moments an "INSTALL WINDOWS" box pops up. The box says" WINDOWS...
Factory reset on acer aspire 5733z-4851 without reset disc. ALT+F10 keys at boot will start Acer recovery process. if this keys combo doesn't work, enter BIOS pressing F2 at boot and check if D2D is disabled, enable it then press F10, save and exit.
The following might later prove of value:
Product support
Then there is a process of booting from a USB stick. But you need an iso file of Windows 7. Microsoft Recovery Center likes retail versions with keys but not OEM versions.
Just something you might need to take a look at.
Aug 11, 2017 | Computers & Internet
I have been trying to fix my brother in laws emachines desktop computer for 3 days now. It has Windows Vista and Intel Celeron D Processor 356. I used the recovery disc and the computer started working...
The disk is corrupted and it interferes with the install process. Just get this
http://gparted.sourceforge.net/
boot from it and format your entire disk to reiserfs then to FAT32 - this way any trace of the old NTFS file system is thoroughly wiped. Now launch the recovery process one more time and it will automatically detect the FAT32 partition and will reformat it to NTFS in the process.
Sep 14, 2011 | eMachines Computers & Internet
When I try to scan my computer does not see the scanner but I have no roblem rinting
This is a common problem with all-in-one printer/scanner combos. Printer drivers and Scanner drivers are installed seperately unless the driver cd is REALLY high-speed (i've never seen it work once). What you'll need to do is open your control panel, go to "scanners and cameras" and click "add an imaging device" (on the left side of the window). It'll start a wizard to walk you through the steps of installing the scanner. Make sure the scanner is connected and turned on, and that you have your driver cd/installation disc loaded. If you dont have the disc, then you'll need to have the drivers in a folder somewhere on your pc, and you'll have to manually point the wizard to that folder. This should square you away. Good Luck
Mar 14, 2011 | Samsung CLX-3160 All-In-One Laser Printer
I KEEP GETTING SOLUTION CENTER POP UPS REQUESTING ME TO PUT IN THE SOLUTION CENTER DISC. I PUT IN THE STARTUP DISC I WAS GIVEN WITH THE J4580 HP PRINTER, BUT THAT DOESNT STOP THE POPUPS. THIS OCCURS ALL...
Hi
follow these steps
1. Disconect your printer from your pc
2. uninstall your printer driver from your pc
3. insert cd of your printer
4. run setup (with out connecting printer to pc untill setup ask you to)
If i had help you pls vote me
Oct 19, 2010 | HP Officejet 5610 All-In-One InkJet...
Lexmark X2500 wont read on the computer (2008 HP Vista).
please try reinstalling the drivers. unplug the printer from the pc, reinstall drivers. restart pc before you plug the printer back in to the pc. after restart, plug printer back in. should work. do you have the install disc for the printer? If you do, and the first fix did not work, plaug the printer into the pc. Put the install disc into disc drive. if the autoplay is running it should ask you if you want to read the files on the disc, just close this window. Then go to START-RUN(type in) DEVMGMT.MSC and find the printer option. expan and right click on the little printer and choose "UPDATE DRIVER" it will then give an option to choose from updating from a specific location or install from a specific location. choose FROM A SPECIFIC LOCATION. another window will pop up with the choice to search from removable media ie floppy, cd etc, etc. choose that option if it hasnt already. It shouls all be automatic from her on out. Good luck.
Jan 04, 2009 | Lexmark X2500 All-In-One Printer
Dvds won't play in dvd/vcr combo cinevision.
I found out what the problem was. I think my son stuck somethin inside the dvd inserter. I found a little cardboard disc inside. Dvd player works fine. Thank you!!!
Jan 02, 2009 | Toshiba Cinevision DVR2000
HP Solution Center Popup
Greetings Sheryl,
My name is Mark and I will be happy to assist you. If that pop up is asking for an update go ahead and allow it. HP for some reason needs to update constantly. Here is one other method we can try. If you are running Vista on your computer go to start then right above start is a search box type in "run" and it will appear at the top of the box go ahead and click on it. A new box will appear you don't have to click anywhere just type"msconfig" and hit the enter or return button. A new box will appear this is your msconfig at the top will be some tabs click on the one that says start. another box will open and it will have programs in it with check marks next to them. Look for all the programs with "HP" in the beginning and uncheck them. Now click on apply and ok, it will prompt you to restart go ahead and do so. When it restarts a box will appear stating that "you have made changes to your configuration, there is a small box in the lower left corner that says "do not remind me again", click on that and ok the box. See if this works Sheryl if not contact me again and we will try somethin else.
Be mucho blessed,
Mark
Nov 12, 2008 | Office Equipment & Supplies
Cant scan with deskjet f370, everything is connected but there is no response when you press scan, the power light just blinks!
hi my name is pete heres how to fix your problem go to control panal then go to add and remove click it find programme for your printer deskjet f370 drivers unistall it the computer will help you once its unistalled your computer will ask you to reset so it can take affect unplug the printer from the computer when your computer starts back up as it normaly would have put your driver disc in what come with the printer and put it in your cd rom it will load a demo up part of your software whats on the disc dont set that up yet now plug your printer back in and you will hear a sound if its usb a window will appear saying found new hardware and another window will appear click next and your computer and it will search for the drivers on your disc it will take some time cos it start looking from your floppy disc then hard drive then it will start spinning your disc once its found them it will start copying files over to your computer when it has finished it will say your new hardware is now ready to use now go to to demo and continue setting up your software for the printer once finished your computer will ask you to reset so it can take affect after loaded back up try your scanner any more problems let me know
Oct 06, 2008 | HP Office Equipment & Supplies
AIO Home Center Problems
i click on the eyecon and this kodax aio home center encountered a problem and needs to close pop ups
May 29, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
No disc found
Most DVD players that would not recognize and/or play a disc even with a known good disc inside signifies that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves) or some other components.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Feb 09, 2008 | Toshiba SDV593 DVD Player / VCR Combo
Fargo Pro L ID Thermal Printer Logo
325 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Computer Links
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
