Question about Bionaire CM1 Humidifier
My bionaire CM1 makes bubbling sound every other minute
Steam is coming out as normal, but i can see water bubbling out from the misting camber pointed bottom.
is that normal? can the noise be reduced (it can get annoying at night
Yes, mine does that too. It got very annoying and I couldn't sleep. I noticed some calcification inside and gave it a rinse. I don't have the manual on cleaning it but after I did that it's much quieter. I think you should try cleaning it.
Posted on Jan 15, 2009
When I turned on my ultrasonic humidiifier it worked for 10 sec, then I observed the water coming through the bottom. When I removed the tank and the bottom full with water. How can I fix this?
Bionaire BWM401 leaking - YouTube
? 0:39
https://www.youtube.com/watch?v=Gy7VKJJeb3o
Jan 20, 2013 - Uploaded by urhorh
My Bionaire BWM401 leaking through the bottom. ... Review ofBionaire Cool Mist Humidifier BCM7932P-CN from Costco HD - Duration: 1:41.
Nov 28, 2015 | Bionaire Humidifiers
No steam is coming out?
Try salt in the water, booklet in mine recomends salt to create steam, but don't add too much or you'll end up with a mini giser!!!
Hope this helps, if not, it's possible that the heating element is bad. Try the salt, then turn on for 1/2 hour or so, remove the cartridge from the water resivore and slowly stick a finger in to see if the water is hot or cold...
Apr 14, 2013 | Vicks Warm Mist V745A 1 Gallon Humidifier
Wont blow out mist
it has a quiet operation when you got it brand new did it put out mist
Nov 02, 2012 | Vicks Cool Mist V400 Humidifier
I turn the humidifier on l or ll. The light is grean but it is not releasing steam or anything. I don't hear a noise and the water level stays the same.
The humidifier may be clogged with a calcium scale build up. Especially, if you use well water or your municipal water supply has a high chemical content.
To solve this problem do the following. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water (enough to fill the tank). Empty any water that is currently in the tank and fill it with the 50/50 solution. Allow at least one hour, before turning the unit ON. After turning it ON place you hand in front of the mist nozzle to see if any mist is being generated. If it's generating mist, allow it to run until the tank is 3/4's empty. Then turn the unit OFF, unplug it and empty the remaining solution. Refill with Bottled Distilled Water and run until the tank is empty.
If the unit did not produce mist after one hour of soaking, allow it to set over night and then follow the procedure above. Generally, an overnight soaking will do the trick. In the future, I recommend using Bottle Distilled Water rather than your tap water.
Hope this helps you solve the problem. Please let me know. Thanks.
May 16, 2011 | Vicks Warm Mist V745A 1 Gallon Humidifier
I just bought this product and the filter meter still reads at the mid point of good and change. Did I get a faulty product? Also, it is normal not to feel or see any mist coming out of the humidifier?
No, it's not normal not to feel or see any mist coming out. Depending on your home's water supply may have presented the problem. Especially if it's well water ... to many minerals. Which will clog the filter. Or your city water supply may be the same.
In any event, I would suggest buying and installing a new filter and using Bottled Distilled water instead. It's inexpensive ... about $1.00 per gallon.
If that doesn't solve your problem, return the unit under within the Warranty Period for replacement of repair.
Feb 09, 2011 | Sunbeam Ultrasonic 81696 Humidifier
No mist is coming out of it but the green light is on.
Hi Lisa,
  • Check that there is water in the Water Tank.
  •  Make sure that nothing blocks the Mist Output Slots.
  •  Check that the Fan Vent on the bottom of the humidifier is not blocked.
  •  Empty the humidifier and rinse the Water Basin with cool tap water and allow to dry for 15 to 30 minutes before resuming normal operation.
  •  Check for possible mineral deposits on the Water Level Sensor or the Nebulizer.
For more information, check out the owner's manual here. It is truly helpful!
Good Luck!
Nov 03, 2010 | Crane Elephant EE-3186 1 Gallon Humidifier
My vaporizer is making a quiet bubbling/gurgling noise. This is only the second time that I've used it, but I can't seem to find the instruction manual. What could this mean?
That is very normal...the sound is the water being turned to steam which is the "vapor" that comes out...
Everything is okay and perfectly normal.
heatman101
Mar 30, 2010 | Vicks V150 Humidifier
Steam not released through spout but trapped
is the spout clogged? Try running vinegar through it, CLR is a good product, but may stay the plastic, if not eat it, so I recommend vinegar to clean the deposits that plug things up, it may smell a bit, but usually works. Once cleaned, use distilled water to keep it from happening again, or just clean regularly with vinegar.
Feb 28, 2010 | Bionaire BU4000-UC Humidifier
Cleaning a Cool Mist BCM6100U Humidifier
usually it calls for one cap full per gallon of water that the unit has. what you do then is that you put the solution in the water then you put the tank back on the base and then you turn the unit on and let the solution run through your unit.
Mar 22, 2009 | Bionaire Cool Mist BCM6100U Humidifier
Bionaire CM1 Humidifier Logo
530 people viewed this question
Top Bionaire Humidifiers Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
