Question about Lexmark Wheelwriter 1000 Typewriter
The cartrdge won't move
We own a Personal Wheelwriter 2 Lexmark and last time we used it the cartridge will not move as we type. We hear a few beeps when we turn on the machine but it won't budge from there. Any suggestions will be appreciated. Thanks! Manuel
  • 1 more comment
  • Manuel Berrios Mar 26, 2007
    Thanks for responding!
    I pretty much did everything you mentioned above, and nothing. When I turn the typewriter on, I get a row of about 7 beeps and also the line space LED's for Line 1 and Line 2 stay on. Is this an indication of some error message? Please help!
    Thanks!
    Manuel
  • Manuel Berrios Mar 27, 2007
    Thanks for your prompt response! The print wheel motor doesn't spin. I checked the white ribbon cable and the connection seems to be fine.
    Thanks for all your help!
  • darkages Aug 22, 2008
    Problem is the same - what was the solution? Have changed batteries & still won't work. thanks.
  • 163 Answers
? Cartridge..Do you mean ribbon cartridge, print Wheel, or Printer Ass'y. Also check line space LED's for error codes. Clean the sensor located on the printer ass'y (located behind the print wheel) with air. Also (power off) make sure the printer ass'y can slide freeley (L-R-L)and no obstructions have fallen into it's path. There is also a printer home position sensor located on the far left bottom of the printer ass'y travel path. Also clean with air. Let me know if you have error codes.
Posted on Mar 23, 2007
  • John Byse
    John Byse Mar 26, 2007
    1+2 can be a couple of things. Flashing LED's during POST (Power On Self Test) are error codes. You might have a problem with the print wheel motor, does it sip durin POST? The other would be the keyboard. Check the connection (white ribbon cable) from the keyboard to the function PCB. I don't think you can buy a new keyboard anymore but you can get your repaired for about $50. If there is a dealer in your area they can probably test yours.
  • John Byse
    John Byse Apr 03, 2007
    Sounds like the print wheel motor is the problem. Once again a dealer should check that or get you a remanufactured one.
  • Lexmark Master
  • 3,594 Answers
Two lights usually means the WW dosen't see the keyboard you can replace the keyboard or try my tip under WW1000.
DickyO
Posted on Aug 25, 2008
SOURCE:
How do you save a document to memory and re-type from there? Is there a re-print button?
If you do not have your instruction book, go to lexmark site and search for it, can usually download a copy, so you will allways have a reference.
Jul 29, 2014 | IBM Lexmark Personal Wheelwriter 2...
IBM Personal Wheelwriter 2 inoperative
sounds like a keyboard problem. You can try my fix under WW1000 or contaqct Geo Beyers Co. fpr KB rebuild
DickyO
Jul 16, 2012 | IBM Lexmark Personal Wheelwriter 2...
IBM Personal Wheelwriter 2 by Lexmark not working
It sounds like the keyboard is going bad see my tip under WW1000.
DickyO
Jun 24, 2009 | IBM Wheelwriter 30 Typewriter
Typewriter only beeps and lights blink. Nothing else.
the beeping and the lights are error codes, meaning the machine will need repair
Feb 25, 2009 | Lexmark Wheelwriter 30 Series II...
IBM personal wheelwriter 2 memory
I have a IBM Personal Wheelwriter 2 by Lexmark and when you turn it on it beeps and then the single and double space lines light up and stay on but the it will do nothing else. (It's like it is locked up
Mar 25, 2008 | IBM Wheelwriter 30 Typewriter
IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Oct 31, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
Lexmark Wheelwriter 1000 Typewriter Logo
188 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
