Question about Reddy Heater-30-55,000 BTU Variable
Remington 60 portable forced air heater 60,000 btu
When i plug it in, after tree sec. the fan will turn and fumes will blow out the front of it for three sec. then the fan will stop please help i am cold
  • 3 more comments
  • lonewolf2001 Dec 19, 2008
    I have the same problem,the igniter glows,the fan starts,fuel is sprayed,then fan shuts down,any help would be appreciated.
  • luckie911 Jan 19, 2009
    I have the same problem too. I have gone thru it all. Filter is fine. Line is okay. Ignitor ignites. Fuel is spraying. I have tried to adjust the air/fuel ratio. I can only get it to run with the cover partially on. Seems like the safety mechanism is getting involved??? Help!! Thx
  • Anonymous Mar 14, 2014
    My oil heater in my basement comes on but it blowing cold air out
  • Anonymous Mar 15, 2014
    Fan turns and blows air but air does not heat up.
  • Anonymous Mar 29, 2014
    The heater will fire and than almost immediately shutoff.
    New Friend:
  • 4 Answers
Check the seal around the fuel tubes; mine was sucking air around the tube causing blow-out.
Posted on Jan 19, 2013
I had the same problem. I took the nozzle head off and blew through it with air. I also blew through the air line, this is the one that goes to motor. It has worked fine ever since.
Posted on Jan 16, 2009
Remington 35 portable forced air heater parts
Top cover is shorting out the spark plug wire.
Jan 10, 2014 | Heating & Cooling
When heater starts up it puffs fumes then lites
Generally, if the heater puffs fumes at start up it is because there is not instantaneous combustion.
What causes this?
  1. Worn nozzle
  2. Incorrect (click for instructions) air pump pressure
  3. Spark plug carboned
  4. fuel filter restricted
  5. Air leak or vac leak between the pump and the nozzle
Generally speaking, if the fuel is being delivered as a FOG not a SPRAY, and the spark is strong and properly oriented there will be immediate combustion at start-up.
Nov 14, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
My heater will rub for a minute or so then shut off ,,,unplug it and after a few seconds plug in back in and will run a little while again and help would be appreciated
Sorry, this is not a solution but some advice, Kerosene heaters can give off dangerous fumes if not working correctly, for your own safety you should contact the manufacturer.
Nov 10, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
When I plug the unit in, the fan turns very slow, and I smell fumes, but the unit does'nt turn on
I am not able to give you a solution, but will put forth some possibilities for you to check.
  1. Spin the fan manually. No power, please. If the fan spins freely, and no grinding is heard or felt, then the starter capacitor or starter relay (whichever equipped) is defective. Internal capacitors are not serviceable. Replace the motor.
  2. If the fan does NOT spin freely and/or binds, either the rotor (air pump) is broken or a motor bearing is bad. The rotor is replaceable, the motor bearing is not serviceable.
If you decide to repair the heater as described then the air pump pressure must be reset, in either case, in order for the heater to burn properly. It is a simple process. Follow this link for instructions
http://www.reddyparts.com/pressure.htm
Nov 02, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Propane 100,000btu heater runs fine but has a lot of fumes, it almost burns your eyes
Go to my tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters for all your answers. Your air fuel mixture is off. You need a new air filter and need to set the bleed air. For that you need special tools which you can get at the information I give at my tip. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Feb 13, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
FLAME PROBLEM WITH REDDY HEATER RLP100, HAS BAD FUMES WITH LITTLE FLAME
Hi it sound like the burner /ports a blocked trycleaning them out should improve flame
Jan 17, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Ready heater 100,000 btu won't fire up!!!!!!!
go to www dot desatech dot com. you should be able to find what you're looking for here.
Jan 13, 2008 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
Dec 06, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-30-55,000 BTU Variable Logo
2,242 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
