Question about Broan-NuTone Best by Broan 36quot; Stainless Steel Backsplash - RMP3604 Kitchen Hood
Range hood runs & shuts off
While flambeeing a dinner entre, the flames reached in to the range hood, a Best by Broan. Several of the fins (4) on one of the fans are now missing. The range hood now runs for a while then shuts off. After a while it will turn on again.
I'd like a service tech to look at this. I'm in east Central PA.
The label inside says the motor is a K-42 REV A
    Genius:
  • 2,035 Answers
Call Best by Broan :
Customer Service at 1-800-558-1711 or Technical Support at 1-800-637-1453 and get it serviced ...
Good luck...
Posted on Dec 16, 2008
    Brigadier General:
  • 5,158 Answers
On the home page of fixya you will find a place you can type in your zip code to find a repair service ... i'd recommend that
Robert
  • 19,396 Answers
My Broan range hood keeps going up and down. Will not stop. I unplugged it and plugged back in but keeps going up and down. The hood is almost 2 yrs old. Pls help. Thank you.
This sounds like something has got into the track area and is setting off the safety. they are designed to stop raising or lowering if they meet any resistance and anything in the track area will cause it to happen in both directions
Jun 26, 2011 | Broan-NuTone Best by Broan DD01 Series...
My Range Hood (Best by Broan K260A) is just two years old in a new house. WHen I use it, fat & grease drip down from the left and right edges against the wall. Can someone tell the problem?
grease accumulation, remove the fours screws on the lower plate, to remove excess grease. further you can unscrew the bolt that are holding the assembly and unplug the unit. after remove fans with allen key and remove motor , clean and reassemble , make shure to put motor the right back the same way. reassemble the same way , problem should be solve for at least 7 years depending on cooking.
Mar 15, 2010 | Broan-NuTone Broan Range Hood Accessory
Broan range vent fan not working; motor humming but will not turn, light works fine, not the fuse.
The motors will go bad from time to time. I would check Broan's web site
www.broan.com
or fill out this form
http://www.centralvacuumstores.com/fan_help.php
Sep 12, 2009 | Broan-NuTone Broan Range Hood Accessory
Can not get halogen bulb out of my kennmore elite range hood
You will have to do the following steps.
1. remove filters
2. Unscrew 2 screws retaining metal plate under the filters.
3. Now you must remove the whole light panel. 5 screws in all, three under the front lip and two at both back ends of the same panel.
4.You now unhook the light wires (plastic connector with two wires)
Now you have the whole pnale in your hands. Unclip the socket of "problem side" and unscrew the socket from the bulb. Re-do steps 4.3.2.1
Jan 27, 2009 | Broan-NuTone Broan Range Hoods Allure II...
My broan allure turns on by itself
Isn't it suppose to turn on automatically? The broan has a heat sensor!
Jan 08, 2009 | Broan-NuTone Broan Range Hoods Allure II...
Damper need for Broan Range Hood
I called tech support at Broan and was told they recommend two dampers in cold climates ...one at in the wall cap and one on the unit. They make the damper,
(#BP87-7"), that attaches to the round duct plate that comes with the hood. Strangely the unit does not include a round damper and the seller LOWES did not have it, also checked Home Depot,.
The Tech said they can't get stores to stock it. I checked at a local supplier of all kinds of plumbing, heating, and cooling supplies and they only had basic 7" dampers which, I was told would probably be too heavy, and be manual. I ordered it through Amazon/True Value ($11.56 w/ shipping, shipping more than cost of damper). Tech indicated that the 2nd (unit damper) is optional and may not be needed if in a warm climate. I would suggest that Broan include the $5.00 item in their unit or at least sellers stock it.
Jun 27, 2008 | Broan-NuTone Broan Range Hood Accessory
Broan fan cat h 500 housing 115v 60 c 1.5a lr 31619
Customer Service: 800-558-1711
Technical Support: 800-637-1453
Oct 13, 2007 | Broan-NuTone Best By Broan BER02IS 48"...
Kitchen Ranges Logo
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
