Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Jenn Air Dual Fuel Fire problems
Many people on Epinions have said there is a fire problem with the Jenn Air catching fire. Have you had any experience with these problems?
  • DC Dweller Apr 08, 2009
    Yes, my 2.5 year old Jenn Air Dual Fuel double oven caught fire last week (firetrucks, the whole nine yards). Major problem with the inginators and gas values. After seeing it would be over $500 to fix, and then not knowing if the others would do the same, we decided to buy a new range last night. I found so many cases online of this problem, I wasn't willing to risk another fire (not with a 5 year old around). I wish I knew this before we shelled out 2 grand!
We decided to go with a different stove. Thanks anyway!
Posted on Dec 17, 2008
The pellets in the hopper on our Louisiana grill keep catching on fire, no amount of cleaning seems to help. Why are they catching on fire and what can we do?
First I'm not a louisiana Grill representative.
* Check your warranty. call for support.
*** Following is for information only.***
* Any item that can burn will burn if it has; Fuel, Air, Space to burn.
* Pellets catching flame means all three items are available.
* Check your "Flame chamber" Is it open for full burn or searing position? (full open where you can see the pellets and lots of air can get to it? This air will allow the pellets to burn quickly.); https://www.youtube.com/watch?v=1R_eloeM0Fw
* Check if your cover to grill is fairly air tight as when it was new. Though the burn chamber is what keeps most of the air out. The lid also helps keep drafts from causing flare ups. Smoking requires "smothering" the fire. Keeping the air out.
* Check if your electrical power (extension cord) is okay.
* Check if your meat probe is still working and calibrated. If this probe (wires) are broken then the feed will think the meat is cold (or hot) and over feed (under feed) the burn kiln.
* Check with your vendor for advice.
Aloha, ukeboy57
Additional information;
* https://www.youtube.com/watch?v=YNXuW2YeMoY
Sep 02, 2018 | Grilling
Jenn-Air gas Cooktop fire is low
www.servicematters.com/maytag_library/docs/16010492.pdf service and troubleshooting manual above.
May 02, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
My stove berner egnighters shorted out manufacturing problem arked a hole in the burner control knob gas was leaking arked by it self started a fire from leaking gas i want assistance imedeatly ive spent...
Hi you needed a good gas fitter to look at this problem , you will need some new parts and the leak fixed , but is the stove worth it , or is it worth putting any more money in to it .
you will have to look at the saftey side of it
hope this helps
Oct 31, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air dual fuel range JDR8895AAB caught fire last week.
The exact same thing just happened to our same model last night. Did Jenn-Air fix it?
May 07, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Igniter of back burner dies not click or light
I had the same issue with washing the top with water and cleaning solution. I had arching, eventually one burner failed to ignite. I tried the above solution and it did not work. Remove the ceramic top on the burner that will not ignite. Turn on another working element. Do you see the igniter working?
If so slowly turn on the gas on the failed burner and it will ignite. I'm looking into what component automatically controls the igniting and gas release when the knob is turned on.
Dec 22, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Oven element on fire
yes that's a common problem. but not because there was a fire on top of the element it mean that is bad. have you try the oven after the fire?
Dec 06, 2008 | Jenn-Air Kitchen Ranges
Jenn-Air part RI302 4 pt gas re-igniter with flame rectification tytronics #Z21-20 and 7431 PO38-60
We had the same problem on a Thermador cooktop with the same RI-302 ignitor. Turns out it was one of the switches that sits on top of the gas valves. These switches cause the ignotor to fire when the valve is turned. In our case, one of the switches had malfunctioned and was "always on" causing the ignitor to continuously fire.
Oct 29, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
351 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
