Question about Electrolux Washing Machines
Water leaking from washing machine, no obvious leaks around hoses, just seems to be appearing on floor underneath
  • penfy Dec 16, 2008
    noticed that the door seal is not attached to the drum, but can't seem to get the spring back around it again, do i need to take off the door seal from the front of the door first? and if so how on earth do i do this
    thanks
    President:
  • 373 Answers
Check the outer tub for corrosion or cracks.
Posted on Dec 16, 2008
    Novelist:
  • 161 Answers
This will require looking on the inside with a flashlight while it's running to see exactly where the water is coming from.
Look at the:
1. water valve while it's filling
2. The bottom seal on the tub while it's washing
3. The pump while it's draining
  • Ron Buice
    Ron Buice Dec 16, 2008
    This is not an easy thing to do. It would be worth your time to call for help.
There is water underneath my washing machine after a cycle. What do I check
check discharge hose where it empties out. Feel up the hose to see if it is leaking back down the hose and dripping onto the floor.
Sep 19, 2014 | Washing Machines
Mav6451aww
water pump, replace
Sep 24, 2017 | Washing Machines
My LG WM1814CW Washer is gushing water from underneath during every wash. We pulled the washer out and checked the hose lines and everything is fine there. What is underneath that could be leaking? Do we...
sorry about your floor! yes you need to pull it apart and see if anything looks funny-if no hoses are loose the tub may be leaking-this would be happening around the door seal-also try to wiggle the tub to check the tub bearing-which could also cause the leaking-if it seems to be loose this could be the problem also-cheers Denny
Oct 28, 2013 | Washing Machines
Leaking water from bottom
Hello there:
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub-
Apr 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
IWater Leak from LG12225FD Washing machine
may be pump...hose seal... in outer tub...cracked inlet valve cracked hose inlet to tub
Aug 17, 2009 | Washing Machines
Two speed auto washer - found water all over floor - no leaks on any hoses or drain. Wife said last load was unbalanced and machine was rocking around bad. Tub seems very wobbly to me when I move it...
having a very unbalanced load can cause the water to go over . yes the tubs are supposed to be able to move around some.run a load with no clothes in it if it leaks then you may have a more serious problem
Jul 26, 2009 | Whirlpool LSB6200KQ Top Load Washer
Washer machine leaking water from underneath
Seems like a leaky hose or pump.
Other than ruin your floor, you should to take caution that if the water sprays onto electrical connections or the motor etc, I may cause a fire or electrocution so it would be wise to have it inspected as soon as possible.
Sep 17, 2008 | LG WM2688HWM TROMM SteamWasher
Washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
May 11, 2007 | Kenmore 44042 Front Load Washer
Washing Machines Logo
326 people viewed this question
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
tom wright
tom wright
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
