Shredder runs in reverse
GBC shredmaster 1676S runs only in reverse regardless of which switch (forward or reverse) is pushed.
fellowesrep
  • 102 Answers
SOURCE: Hello, I have a GBC Shredmaster 6120S
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol.
If neither of these help your paper feed sensor or your pc board has gone bad and you will have to contact your manufacturer for further parts availability.
Posted on Mar 02, 2008
fellowesrep
  • 102 Answers
SOURCE: Shredder not working
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Sensor is usually located in the center of the paper feed opening.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
  • 35 Answers
SOURCE: I HAVE A MODEL SPL-1506X PAPER SHREDDER, YOU HEAR
The optics are OK!
There is a small electromagnetic sensor on the cuttershaft which senses the input load.
I could be maladjusted or defective.
Posted on Feb 23, 2009
t_vinson57
  • 58 Answers
SOURCE: GBC SHREDMASTER 4220S
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
  • 3 Answers
SOURCE: How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
Posted on May 27, 2009
Hi I have a GBC Shredder, made by swingline, model GLX2030. Since this morning the shredder didnt stop! Normally the shredder work only when we put paper into...but today we have to push the ''ON'' button...
There is an infeed sensor that isn't being made for auto on which is just a simple flipper switch and if it doesn't work it is because there is paper jamming it. Unplug it and turn it over where the blades are and see if clogged up and if so than put back on and reverse it and than forward again until it releases if it has a reverse ,reverse it. If no reverse unplug and use a narrow object to clear from the bottom side
Mar 28, 2011 | Gbc GLX2030 Shredder
GBC shredmaster 1150x shredder now runs only in reverse. And when I press the "reverse" button, the green "forward/shred" light comes on, rather than the red "reverse" light....
The first thing that comes to mind is that the switch is faulty and that one of the contacts has come loose and is shorting across the reverse contacts. There is little else that can go wrong with a shredder, so in this case try replacing the switch.
Jan 26, 2011 | Quartet gbc 1150X Shredder
It will not grab the paper; need to press forwared
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Quartet gbc Shredmaster 6550X...
My shredder is stuck in reverse. How do I get it to go forward?
Unplug, open and remove all partly shreded paper fron the underside, then try it again. If it is hot to the touch, let it cool for about 15 minutes before trying it again.
Dec 19, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
DISCONNECTED WIRE
I clipped all the zip ties to free up the harness and physically inspected every connector till I found a connector that seemed rather loose and came off with minimal force. I then gathered the 3 wires and install a #18 wiring nut. the shredder is fully functional again.
Jun 03, 2009 | Quartet gbc GBC 10-Sheet Cross-Cut...
May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
107 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
