Question about Danze Plumbing
Trouble to have hot water continiusly
When I open teh hot water valve, it does not flow continiusly. It almost stops. And it does like blocking in the pipes. I dit remove all the valve components and replaced them, and still it will not flow properly
    Scholar:
  • 44 Answers
Hi there well it seems from what you have written you must of stopped the hot water at some point to remove the valve components & to replace them, from the small amount of info you have given I suspect its an air lock in the hot water supply pipe somewhere?
If this is the problem you might find its affecting the other hot taps possibly? if your able to narrow it down to a single appliance, then it could be localised.
Now the air lock can be removed if it s as we suggested. Do you have a wet & dry vacuum if so run the tap closest on the hot then put the wet vac around the tap & turn it on for a few secs being careful not to get scalding water on you? this will hopefully move the airlock & get you back in business?
If not then post some more info & I will see what i can do for you....good luck
Kindly
Richie
Posted on Dec 16, 2008
Hot water doesn't fill when selected.
tap not turned on
hot water solenoid burnt out and not opening flow control valve
tap washer blocking the water flow in the tap
Dec 11, 2015 | Washing Machines
My Saeco Incanto Sirius machine keeps asking for yet another VENTILATE cycle
This means the water cannot flow through the machine. Normal fix is to prime the machine (turn water dispenser on, fill a cup) or descale the machine. Go through the menu, select descale, enter, then turn the steam knob fully anti-clockwise. You should put the descaling solution in the water tank first.
If you have the auto-descale in the menu then run it. Run the solution through the machine twice. Then rinse well.
Oct 03, 2008 | Saeco Vienna De Luxe Espresso Machine
Hot water has great flow. Cold barely drizzles out. NOT a water pressure problem. What/How to check on faucet?
Faucet may have scale desposits on cold water side that would restrict flow. The shut-off valve for the cold may not be opened fully. If a saddle valve for refrigerator ice water was installed, it may block off flow for cold water. Check these items first, then ask more questions.
May 11, 2015 | Plumbing
I am getting no water from the hot side of all my faucets cold water works fine
Sounds like the water inlet valve to your hot water heater has been closed (turned off) If the tank has no water coming in, it can't put anything out.
Mar 21, 2015 | Plumbing
How do I unblock filter of washing machine
Turn of hot tap and disconnect hot water hose from inlet solenoid, using long nose pliers pull out filter from solenoid.
The problem may well be the solenoid needs replacing as they do tend to fail occasionally.
Oct 10, 2014 | Fisher and Paykel GWL11 Top Load Washer
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Sep 18, 2017 | Bosch Axxis WFL 2060 Front Load Washer
I just bought my hot tub, it shows ''FLO'' on the panel when i turn it on. I did every thing they say on the panflet but it still doesn`t work. Anything else i should do??
The problem is that the flow switch for your water heater is indicating no flow. Therefore your water heater will not operate. Without proper water flow your heater will burn up. Check that your valves are open. Check that your pump is running. Check that your filters are properly installed and not restricting flow. Check the wiring to your flow switch and make sure the flow switch operating properly (i.e. put a ohm meter across the contacts and see if you have continuity when the switch closes).
Sep 18, 2010 | Apollo Pool & Spa
Water Heater Keeps Going Off
is there a check valvle on hot water side of heater,a flow restriction of some sort, water pressure to the heater, a filter in the line, line pressure in the heater kicks out burner, when you turn on the water, line pressure drops, heater comes on, when you turn on water in other part of house, heater should not fire, so there has to be a check valve somewhere,in heater?
Jan 24, 2010 | Noritz 6.9 Gallon Residential Tankless...
The hot water stops coming out of faucet
if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
Apr 12, 2009 | American Standard Kitchen Faucet 6310 020...
Plumbing Logo
108 people viewed this question
Top Danze Plumbing Experts
john h
Andrew Bugbee
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
