Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
No power to control unit in fridge
Several days ago, I opened the refridgerator on my 4 yr old whirlpool gold series side by side fridge. The light blew out. Not a problem originaly since the light lasted 4 yrs. The next day I realized there seemed to be no power at all to the setting indicator lights and filter status light that is also housed within the same unit as the light. I then changed the light and it will not work. Since the fridge freezer seems to be working fine, i assume it is a fuse but don't know where to look. First thought is that it may be within the door open switch that could have gone bad? Is it as simple as replacing the door open light switch?
  • fio1637 Dec 18, 2008
    I had the same thing happen this morning. I have a repair man on site right now. He says its a control board and just went back to his shop to get a new one.
    I'll post again if this fixes the issue.
  • beenther1 Dec 30, 2008
    My refrigerator is just about 5 years old. The other day my wife opened the door and there was a pop and the lights on the control panel and the refrigerator lights went out. There is a clicking noise when the door is open. I am guessing but I think there was a voltage drop when whatever snapped because the light bulbs have a strange orange glow, as if there is not enough voltage to light them up. The refrigerator and freezer are maintaining temperature I just do not have light or the control panel lit up. Sounds like the aforementioned $400.00 fix. I will NEVER buy another Whirpool product.
Turns out we had a bad control board. One of the coponets was blown and it had to be replaced. $400.00 and its good as new.
Posted on Dec 18, 2008
Whirlpool refridgerator ice machine mod.ED2PHE water will not come into ice machine. it was working fine until 2 days ago.
check water line is open, check filter seated properly,make sure of on/off lever or switch or turn off water supply to fridge and check line for possible clog, and also on filter
Jan 24, 2013 | Whirlpool Refrigerators
My whirlpool gold refridgerator- w/freezer on bottom- is less than 1 yr old and has started freezing everything in the fridge.
The temperature thermistor may need to be replaced. If under a year old should be covered under warranty.
Nov 13, 2010 | Whirlpool Refrigerators
Whirlpool model HAXNQ : lights out on fridge side only
Hummm... I would suspect your DOOR SWITCH on the fridge side... $11.321 shipped... eBay!
Anthony
Whirlpool 1118894 Door Switch
Dec 02, 2017 | Whirlpool GS5SHAXN Side by Side...
Whirlpool Gold refrigerator is not making ice. Just stopped 3 days ago for no apparent reason. Fridge is 6 months old.
as long as the fridge is working properly the only thing that it could be would be the icemaker...the fridge should still be under factory warranty if it's 6 months old so they should cover it
Oct 03, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Whirlpool gold refridgerator light not working and is making funny noise
switch of your refrigerator then try replacing the light that doesn't work then try to switch it back on. the light might be the cause of the noise. it might be grounded. replacing the light might reduce the noise then observed the noise for a week then if it still making noise that's the time for you to get a technician that could fix your refrigerator.hope it helped... send us a message for more concerns thank you...
Jun 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Gold Ice Maker Quit Working
IF THE FRIDGE IS COOLING AND FREEZING WITHOUT AND HASSLE THEN YOU DONT HAVE A PROBLEM WITH YOUR CONTROL BOARDS.ALSO IF THE WATER IS STILL COMING OUT THE WATER SIDE OF IT.YOU NEED TO LOCATE THE WATER VALVE AND CHECK IF THE VALVE TO THE ICE MAKER IS NOT BLOWN THAT MIGHT BE THE CAUSE OF THE FRIDGE NOT MAKING ICE.
GOOD LUCK.
MOHAMED
Sep 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refrigerator
YOUR FRIDGE DAMPER CONTROL COULD BE FAULTY IS TO THE TOP LEFT BACK OF THE FRIDGE COMPARTMENT.GOOD LUCK.MOHAMED
Sep 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Our fridge does not make ice - Whirlpool Gold side-by-side GS5SHAXNT00
Same as others. Whirlpool Gold side-by-side. Water was running yesterday but minimal ice. Now that's gone and I don't even hear the water. Turned on/off the infrared sensor. Still get drinking water, just no ice in the bin. There's a couple cubes in the maker itself when I open the door (which I've closed completely). Help?
Dec 02, 2007 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
187 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
