Goodman GPC1342H21A Air Conditioner Logo
Doug Posted on Aug 04, 2012
Goodman package unit pgb036075-1 issues. No light on control board
Yes, i Have power to unit. Have replaced board, and still no light. Have power to the 240V/24V trasformer(which comes from the board?) above board, but no 24V coming out of transformer. Replaced Transformer, still same result. Why am i not getting a 24V reading? Replaced Contactor, Control Board, and Transformer. No response what so ever at the thermostat as i am not getting any voltage back to it from the unit.
almxracer
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 58 Answers
  • Posted on May 16, 2014
almxracer
Contributor
Level 1:
Cheetah:
Night Owl:
Answers
58
Questions
0
Helped
19950
Points
64
There is a fuse on the board which is very hard to see it is a three amp automotive style fuse most people cant find it it is purple in color look very closely using a flashlight
1 Related Answer
Anonymous
  • 26 Answers
  • Posted on Jul 07, 2009
SOURCE: I have a goodman furnace and ac unit the fan and
Look at the contactor on the condensing unit, remove the low voltage wires to the contactor and turn on the system. If the low voltage fuse doesn't blow, replace the contactor.
3a fuse blowing on the blower motor board
The 3 amp fuse blowing indicates some control function is either grounding out (probably a worn insulation on control wire) or one or more of the solenoid controls is pulling more wattage than it is designed to draw. The solenoids for the main contactor and reversing valves should only draw about 0.1 to 0.25 amp. Any more than this the solenoid overheats and causes the control fuse to blow. I have actually had to replace the thermostat wire on some units because the control that was pulling more than designed caused the entire length of thermostat wire to overheat and break down the insulation, causing the control wire to short to the common wire or others and cause more than required operations to occur simultaniosly. One unit had a short and emergy heat was coming on the same time cooling was on.
2answers
Goodman package heatpump blower motor contant running
check your themostat fan mode switch to see if it in on or auto. It should be in auto. If this does not stop indoor fan motor, (it may take up to 2 minutes for the fan to stop, preprogrammed shutoff in the thermostat and fan control cards may make you think the fan has not stopped ) If this does not stop the fan the fan control board in your air handler has a green wire shorting to 24 volt signal in the theromostat wire or the contact on the blower control card is stuck and will need replaced.
1helpful
3answers
Open rollout or open fuse on Goodman
the fuse is located in the circuit board in the blower compartment and the roll-out is located in the burner section and can be a reset-able switch style or the one time fuse link style which is a a small silver cylinder and is mounted in a ceramic piece and is held in with one screw. Both of these are mounted around the opening of the your burner assembly near the opening. This will be near the area of the gas valve.
1helpful
Goodman Furnace not working again????
You can try the 4 amp fuse thats on the inside of the unit, on the board, if you feel confident that there is 120v going to the unit. Having issues with the board can be a bad sign and not knowing what they have already done to it kinda leaves me in the dark, but you can try that and if the fuse blows again, you have other problems going on that they will have to trouble-shoot. The unit is still under the 5 year warranty so it might be best to try and get another board all together, you should only have to pay labor cost. It could be the transformer too, you can check it with a meter to see if your getting the 120v going in and 24v going out if capable. Hope this helps some and good luck!
My goodman gas furnace is not kicking on. the light on the unit is off. The fan is not working. The manual says it is a ''control failure.'' Is this my circuit board?
I would check and make sure there is proper voltage to the unit before I replaced the circuit board but yes they are referring to the circuit board.
Need wiring schematic for a goodman 4ton unit model #mle48-1b
There should be one packaged with the unit. Shut off the power and open the metal enclosure around the control board.
--W/D--
2answers
Gas Package Unit Keeps Running with all T- stat wires unpluged at the unit?
does that unit run heating or just the fan run? if just the fan you may have a bad fan thermostat
I have a 5ton package unit electric/natural gas. unit is 2yrs old. There is 220 v0lts to the unit. unit will not come on. there was some voltage surge during bad weather at the time unit went down. the...
This can only be 1--of 2 things, (the easy fix first, transformer or curcuit board is bad) .If you have 220 volts then check for power going into the transformer, (220 vt) and then power going out, (24-28vt) (90% of the time, its the transformer, 10% of the time, its the cuircuit board.! , i
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
