Question about Tefal Elegance Brushed Chrome Cordless Electric Kettle
Kettle keeps Turning off and on.
This just started a little while ago. When you turn the kettle on it starts up and eventually the water is boiled. But if you hang around for the in-between you will notice that the water keeps fluctuating between boiling and not. The little green light on the base of the kettle is also turning on and off. Some times flickering. We have tried cleaning the contacts and moving to a different plug. Any other thoughts??
  • 944 Answers
Try descaling the kettle for about an hour with some white vinegar without heating. Hopefully the problem is caused by limescale on the thermostat/thermocouple and this will cure it. If this doesn't seem to help then probably the thermostat/thermocouple is to blame, and although easy to replace, it seems that the best way to get the right bits is an authorised tefal dealer. This link will get you the user manual for your kettle if you need it; http://www.t-fal.ca/tefal/products/product/index.asp?univers%5Fid=400&dept%5Fid=430&sku=L00056&mscssid=JXT37R7ERWKH9P2URRA8CLM0SHMF327C Also it has the contacts for tefal customer service(Canada) if you need. Hope the descaling helps, it usually does the trick :)
Posted on Mar 22, 2007
SOURCE:
Kettle keeps turning off before it is boiled
Sounds like the thermostat has gone out of calibration. If you're handy with appliance repair it might be possible to purchase (internet) and replace that part - they're usually not adjustable. Otherwise it's a new kettle.
Mar 01, 2018 | Morphy Richards Kitchen Appliances -...
I have a new Bellini electric kettle. When I turn the kettle on, it starts to boil for a few seconds and then turns itself off. It will boil if I hold the "button" down for a while until it...
Unfortunately the problem is in the switch mechanism, and will need to be replaced to correct the problem. My sense is it would be cheaper to replace the kettle than trying to find somebody to repair it.
Mar 13, 2011 | Kitchen Appliances - Others
Kettle does not automatically shut off even when water is at above minimum level and boiling
I think that standards require an auto-shutoff on electric pots to keep the component from softening down. You could override the shutoff by either taping over the switch or utilizing an elastic band. You can check deep details on electric kettle review sites.
May 15, 2010 | Chef's Choice 677 Cordless Electric Kettle
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
Jul 04, 2009 | Breville "Ikon" Tea Kettle Electric Kettle
Water kettle does not boil water
I had the exact same problem. The kettle would warm water but not boil. I bet you have hard water - try putting 1/2 vinegar and 1/2 water mix and turning it on. I did this, fixed the problem!
Nov 29, 2008 | Kitchen Appliances - Others
Overheating kettle
this same thing happened to me
Sep 10, 2008 | Bravetti EK119H Electric Kettle
Sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Nov 17, 2007 | Bodum (5600-01USA) CURL Electric Kettle
Tefal Elegance Brushed Chrome Cordless Electric Kettle Logo
1,009 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Gerry Harvey
Gerry Harvey
Andrew Taylor
Andrew Taylor
paul
paul
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
