Question about Acer Aspire 5610-4648 Notebook
Green color The screen seems to be getting week. As the laptop warms up, green dots replace the other colors. Where can I have it checked out? Thank you
Balck color turns into green
are the dots appearing in diagonal lines or randoml across the screen? This would suggest to me either a loose connection in your cable or the screen is faulty and will need replacing. Sorry for the bad news
Oct 25, 2009 | Computers & Internet
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
Toshiba laptop screen dicstorted
Loose electrical connection or its loosing its grip to hold your screen. If you can do it on warranty then try. Or have it check by a technician.
Apr 07, 2009 | Computers & Internet
RCA DLP TV with a red dot in the middle of the screen
Sounds like the color wheel stopped and re-started. It may continue to function for a while, but could fail at any time.
I've also seen on rare occasion, a defect in a lamp produce uneven color rendition, but its far more likely that the culprit is the color wheel.
michtech
Feb 13, 2009 | RCA D52W19 52" Rear Projection Television
Color Display problem
it seems that problem that ur facing is manly related to drivers but try booting into safe mode and incase ur screen look normal in it try installing the driver from support.dell.com.or check in bios and check the screen in case ur screen is still bad then contact dell
Feb 03, 2009 | Dell Inspiron 1501 Notebook
Color seems to be pealing up from the bottom of screen
If the screen is bouncing...expanding/shrinking you need to get a repair kit from www.TvRepairKits.com
If your screen looks 3d in color, has a stationary bow, or if you can't adjust one or more colors from the "convergence" menu you need to buy a convergence repair kit. You can get one from the same site listed above.
Hope this Helps,
Nov 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
42EDT41 colored snow/pixels
I have the same green dots that are seen especially when the bacground picture is dark or black. Mine does not seem to be changing when it warms up, and I also get it on my digital cable as well as on any DVD's I play. Please help with any advise. I think it was always there, but I assumed that a dgital cable upgrade would fix it - I should have known better...
Thanks a bunch in advance...
Oct 22, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Green Screen After Warm Up - 50v500
Some of the components in the video processing boards most likely have become thermo sensitive. Over time, they will fail completely. The service rep will change the processor boards that have the fault.
Jerry G.
May 10, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
TV turns off with balck screen and small color dot in center
Best Educated guess would be your Flyback transformer is failing. Not something you can replace at home and the value of the part may exceed the replacement value of the set by the time labour and part are factored together. DO Not look to replace this part yourself as this part inside the set as it has a high voltage that can be lethal. Output voltage can be around 50,000
Oct 29, 2007 | Televison & Video
Color problem
i dont know if this will help , but i bought a rca and a month later i had a big green spot in the middle of the screen, the tv repairman replaced one of the three color modules
Oct 20, 2007 | Televison & Video
Acer Aspire 5610-4648 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
