Question about Microsoft Xbox 360 Console
Xbox 360 Slow Game Play
We have two 360's both are hooked up to HD tv's with composite cables and both were bought at the same time. The problem is one will play games faster and smoother than the other, we have two copies of tye same game PES2009 and one is noticable quicker than the other in normal single player game (not on live)it has been back to Microsoft but it is still the same, Any ideas?
  • 40 Answers
SOURCE: call of duty 4 xbox live
Yes you can play 4 players on it. There might be a problem with your router.
Posted on Feb 20, 2008
SOURCE: xbox 360 unreadable disc
THE SAME THING HAPPENED TO MINE I SENT IT TO MICROSOFT AND THEY FIXED THE PROBLEM. IT USUALLY IS THE DISC LASER THE READS THE DISC.
Posted on Apr 29, 2008
john1304
  • 37 Answers
SOURCE: reading games problems + others
It sounds like the xbox's drive is ready to pack in. unfortunately it sounds like it is going to have to go back to microsoft.
- John
Posted on Jun 23, 2008
  • 10 Answers
SOURCE: Why wont my NBA 09 live game would not play in my xbox 360.
Is the xbox showing any error message at all? It is possible that the disk is damaged, or that it needs to be cleaned. Is this the only game that this problem occurs with? Please contact me at loganhrrs@yahoo.com. God bless.
Posted on Mar 30, 2009
SOURCE: how do i get xbox 360 to copy game so i dont need disk to play?
for u to do that to copy a game to ur system ur xbox needs to be Modiyfied to copy a game
Posted on Apr 02, 2009
I have a daenyx lcd tv, model DN-15, input 12VDC-4A and am trying to hook it up to an xbox 360 console.
If you are using the Red/Yellow/White cable, that's composite cable, but if you're using the one that's Red/Yellow/White/Blue/Green, that's called component. So basically, you set your TV's input to the corresponding color match. 5 colors: Component, 3 colors: Composite.
Sep 13, 2014 | Video Game Consoles & Games
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
Xbox 360 hdtv connection help!!!
Yes, you will need HDTV compatible AV cables.
Jun 25, 2009 | Microsoft Xbox 360 Console
Dont know where to plug the cables in on my tv
Depending on how old the TV is, you may have to resort to using the composite plugs (red, white, yellow) plugs instead of the HDMI or component plugs as used with newer hdtv's. Your XBOX should have these cords or adapters available within the packaging. Just double check that you have these in the back of your TV.
Apr 16, 2009 | Microsoft Xbox 360 Pro System Console
Syncing problem? Xbox 360
Is your TV a HD TV? Be sure to go to options and synchronize the game. There are delays with HD TV's and the GH/Rock Band games.
Also, try using a wired guitar to see if there is a problem with the wireless guitar you are using.
Hope this helps!
Apr 04, 2009 | Activision Guitar Hero III: Legends of...
Xbox360 hd hookup problem---1080i
Your component cable is probably switched to the HD setting. You have to switch it back in order to get video when hooked up to a regular TV.
Jan 30, 2009 | Mitsubishi WS-55857 55" Rear Projection...
Resolution problems/ Game problems
Well it might be becuase your ps3 is european. Im no expert on the matter, but when i bought an hdmi cable and hooked it up to my hd compatible tv, i switched to the hd input (which happened to be input4 on my tv) and a message popped up saying that the ps3 has detected hd output, would you like to change settings? and it did it automatically after i hit yes.
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Xbox 360 turns on, but nothing shows on the screen
If the person that you bought it from on E-Bay had an HD Television. Then the Xbox console is set into HD from the Display options. If your TV is not HD, then It will not display. It can also be the other way around, if His TV is standard and yours is HD. Also try looking at the RCA's(The Part that plugs into the 360) And you will see a slider. Switch the slider, then turn it on. Tell me if that works, if Not, tell me and I will tell you what to press on your 360 controller to set the other menu. Hope this helps.
Jul 11, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Xbox 360 has sound but no picture on HD setting
Is the tv rated for HD? if its not the inputs will be at a wrong voltage and will create that snow like effect.
Is the TV you normally game on HD?
Dec 16, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
138 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
