Question about Pioneer PureVision PDP-5040HD 50 in. Plasma HDTV
HDMI inputs on my PDP-R04U are not working
Hdmi
From home set up on remote, choose option, enable HDMI.
Posted on Dec 17, 2008
Hdmi input not working
Do you have a second signal from your cable box going into the TV by a different port?
You can only use one or the other, not both.
Apr 19, 2014 | Pioneer PureVision PDP-4304 Television
Only One HDMI Input Works
with hdmi plugged in take power cable out of apple tv ,put power plug back in then look to see if you have a signal....
Feb 05, 2018 | Pioneer PDP-425CMX 42 in. Plasma...
Hdmi inputs
Yes, it has two HDMI inputs on the rear of the TV.
Jul 28, 2013 | Pioneer PDP-5071HD 50 in. Plasma HDTV
Can't seem to get the av and hdmi inputs to work ?n my pioneer pdp 507xd plasma
Make sure the cable is plugged into input 5 if your tv is on input 5. Make sure that you don't need to be on the AV input. I suggest using a hdmi cable also to bring the resolution up to 1080p. Make sure the wire isn't shorted also.
Apr 11, 2013 | Televison & Video
My pdp r04u media reciver red and green ligth not blinking only stady lit when i hook up my plazma with laptop i get green light blinking no picture just i want to know what happen my pdp-r04u problem
if this is only with the laptop,, you need to replace your hdmi board if its with the cable
and you receive sound and no picture replace the tcon board. if you dont have neither
picture or sound replace the power supply.
for any parts you can order at tvpartsandmanuals. com
Dec 14, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
(Pioneer PDP-4340HD Plasma with PDP-R04U Receiver) My HDMI input works, however having a computer or Xbox connected via HDMI I do not have the optical output signal thus I can not hear audio through my...
I don't have a direct solution but I am having the same problem when connecting (1) my Apple TV (2) my Blu-Ray player, etc. via HDMI. I also have a digital camera that puts out HDMI, and when I hook it up, I get the same story -- video only, no sound through the optical digital output of the TV receiver.
I am guessing that the HDMI inputs were an afterthought on this model, especially since the printed manual doesn't even show or mention the HDMI inputs at all! So my guess is that the TV's receiver does not convert the sound from the HDMI to the optical digital output. It does, however, send the amplified HDMI sound to the stereo speaker outputs on the monitor. It appears that only the digital tuner's 5.1 sound comes out on the optical digital output.
This is what I have observed, for what it's worth.
Nov 04, 2010 | Televison & Video
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
Input 1 for hdmi stopped working. Input 2 works
Reset all setting back to factory setting.Unplug,replug,should work,if ur backlight video it good,not any coponnents damages.
Dec 22, 2009 | Pioneer PDP-5060HD 50 in. Plasma...
Hdmi input on pioneer pdp-r04u doesn't work. The component cables work, but not the HDMI. The digital audio works.
the r04u comes factory with hdmi DISABLED, hook up your hdmi device, and turn r04u to the hdmi  input (input 1 or input 3)  then:
To activate the HDMI terminal:
1 Press HOME MENU.
2 Press /  to select “Option”, and then press
ENTER.
3 Press /  to select “HDMI Input”, and then press
ENTER.
4 Press /  to select “Setting”, and then press
ENTER.
5 Press /  to select “Enable”, and then press
ENTER.
there you go
Sep 04, 2008 | Televison & Video
Pioneer PureVision PDP-5040HD 50 in. Plasma HDTV Logo
1,407 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
