Question about LG 42PX4DR 42 in. Plasma TV
Funny noise on LG TV
Hi, I've had my TV just over a year and this seems to be getting worse. It is a 37" LCD LG and has a great picture. The problem is the sound, it seems to have a slight background high pit noise that comes and goes, recently it has been there more often than not. If it is on mute I can still hear this noise. Please help as it's driving me mad!! Thanks
    President:
  • 3,130 Answers
This is a problem with alot of TV sets. Most of the time, women can hear this alot better then men because they have better hearing then men. There is what we call in the buisness, a "singing coil". The problem could be simply the coil is singing and will need to be replaced because the windings of wire that makes up the coil is not wrapped tight enough or this noise could be the sign of future problems to come as a bad switching power supply capacitor or a capacitor going bad. I am sorry to say there is not alot an end user can do except call out a tech to have a look. Good Luck
Posted on Mar 21, 2007
SOURCE:
My lg tv has sound but no picture
Sounds like power supply is failing
Dec 24, 2017 | LG 42LC2D 42 in. LCD HDTV
No sound on lg 37lc7d 37 in lcd hdtv
Apparently something else has failed on the circuit board(s).
Nov 10, 2013 | LG 37LC7D 37 in. LCD HDTV
Sometimes when we turn the tv on it will power up but no picture
make sure cables are right because one could be loose or in wrong place
May 27, 2012 | LG 37LC7D 37 in. LCD HDTV
I have a LG tv and now i can´t get any colour???
Do a hard reset, there is a setting in the menu to put the set in monochrome mode, i think that is what has happened
Jan 07, 2018 | LG 37LE2R 37 in. LCD TV
Lg 37lc7d with no picture or sound but green light comes on . popping noise preceeded problem. no obvious blown capacitors
Ur tuner board is dead.Replaced this board to get picture back.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 10, 2010 | LG 37LC7D 37 in. LCD HDTV
37" Philips LCD no sound.
Maybe the antenna that you are using is not picking up sound from the channels. It could also be the cable. If it makes a humming noise, it means that the speakers are getting electric current and that they SHOULD be okay. It also could be your tuner. Maybe check it all out at some tech place like best buy. Those guys can help
Aug 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Cracking noise SAMSUNG LCD TV
I wouldn't recommend doing anything yourself because you can easily make the problem worse. I would recommend calling samsung because it's been under a year and see if they cover the problem. If you open the tv, that could void the warranty so I would try samsung before doing anything to it.
Oct 20, 2008 | LG RZ-37LZ30 37 in. LCD Television
Loud cracking noise sounds like fireworks and wont get a picture
It seems you have loose or cold solder joint connection problem,causing a cracking sound.The solution is to reworks or resolder the solder joint connection in power supply section, audio section and inverter section...
Hope this may help you;
Regards,
VOTIT
Sep 25, 2008 | LG RZ-37LZ30 37 in. LCD Television
Sound problem
sounds like a fan issue that would be myfirst guess
Mar 21, 2007 | LG RZ-37LZ30 37 in. LCD Television
LG 42PX4DR 42 in. Plasma TV Logo
238 people viewed this question
Steve Allison
Steve Allison
