Question about Canon MF8180C Color Laser MFC Printer
Paper has jammed showing error code 0000064 and inform to restart
I have the machine canon 3300. while running the machine, paper has jammed at the left lower door and show the error code 0000064 and inform to restart the machine. when i restart the machine the same problem occurs. wat should i do?
  • Anonymous Jan 07, 2009
    Paper zam in IR Canon Copier pls find solution
  • mustafa kamal mohamed
    mustafa kamal mohamed Mar 30, 2017
    go to sp mode/service mode by pressing *28* /find dev /adjust to min value of 30, good luck
Canon3000 err code 64 restrt machine 10 to20 copy after code please help me
Posted on Jun 11, 2011
I have cannon ir 3300 image runner it shows paper jammed in right side but there is no paper jammed in any side of the machine
Manoj, Try using compressed air to blow dust and debris out of printer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix paper jam Canon iR3300 printer
Home Canon Italia
https://www.usa.canon.com/internet/portal/us/home/support/details/copiers-mfps-fax-machines/support-multifunction/imagerunner-3300
Aug 20, 2016 | Canon Ir 3300 Black & White Copier
Paper jam error canon lbp 3300
1. Open the cartiage then you will show the page just remove or
2. Open back part and remove page
Oct 13, 2012 | Canon LASER SHOT LBP 3300 Printer
I have an error code E000007-0000 after a paper jam in my Canon ir3300. I wish to get a solution on this
these error stands for problem with the reading of fixing film in fixing assy.
If you had a paper jam, its possible that piece of paper stuck-ed on reading path of sensor or the fixing film is worn out and it needs to be changed.
To check for paper leftovers, open the left side way door and check the fixing unit for leftovers of paper.
Hope that helps!
Apr 26, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir 3300 machine error code 0064, plz suggest
CLEAN THE DUST & WASTAGE INK ON TRANSFER CARONA IN MACHINE & RESTART IT .
Dec 20, 2010 | Canon imageRUNNER 400S Copier
ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR APPEARING ON THE SCREEN OF CANON IR 6000
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
Apr 23, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Reset error codes for Canon imageRUNNER 3300i
We followed the instructions from your tech. on which buttons to press to get into the menu function and then followed the directions for clearing the error code. After that turned the printer off and back on and the error code reset and the printer worked like a champ.
Jul 02, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon MF8180C Color Laser MFC Printer Logo
163 people viewed this question
old marine
old marine
