Question about AEG Lavamat W1050 Front Load Washer
Aeg washing machine
My Aeg 1050 front loading washing machine is leaking water from underneath the powder drawer when its filling. The water is running down front of machine and creating puddles. whats wrong with it and what can I do to stop it.?
  • 4 more comments
  • violet macleod Mar 21, 2007
    Hi ive just come on to tell you that after browsing some othr solutions to my soap drawer problem, I have just this minute switched the machine off, got a torch and a long wooden back scratcher and I basically just poked at anything that looked like soap gunk and there was a lot of stuff that looked like soap gunk! machine is now on and hey no water out the underneath of the drawer. very unscientific and I hope not dangerous but it has worked.
    Teliov
  • Anonymous Mar 17, 2014
  • Anonymous Mar 21, 2014
    water runs down the front of the machine while the washing cycle is running. Making a puddle underneath washer. How to stop this leak
  • Anonymous Mar 22, 2014
    Slow water leaking under washing machine
    While the machine is filling up water is pouring out from underneath the machine.
  • Anonymous Mar 31, 2014
    aeg washing machine the time shown on the display will suddenly drop
    President:
  • 1,462 Answers
You may have blockage in pipe from drawer to tub but more likely the soap drawer is clogged. take it right out and clean thoroughly
Posted on Mar 21, 2007
Remove detergent drawer
If powdered detergent is used, water is directed through the drawer to flush it into your washer.
Jan 11, 2014 | AEG Washing Machines
Machine not taking powder
From your comment the water feed into the wash powder section of the dispenser tray is not working properly. Follow these instructions for first removing the dispenser and thoroughly cleaning and then clean all of the jets where the water is supposed to enter. Afterwards replace the dispenser;-0)
Try the following- in the second and third cases whilst looking from underneath!
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit).You may have to push the bottom of the dispenser upwards.
  • lift upwards on the tray as it is coming out to clear the lip underneath. Again you may have to push the bottom of the dispenser upwards.
Pull out the dispenser drawer far enough to be able to just see the trays, select each part of the cycle in turn (briefly to save time) and check that water is entering the trays. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 17, 2011 | AEG Lavamat 72640 Front Load Washer
Its actually the 72630 lavamat. Fabric softener remains in the drawer. Have tried cleaning the drawer but nothing is happening. Any ideas? Many thanks
Sorry- my wife is calling but here is a quick probable fix- the fabric softener drawer normally has some sort of cover, which needs to be removed, and underneath is a pipe/tube down which the softener and water mix siphons. This tube gets blocked by gunge- a mix of powder and softener. Ours does!
It has to be completely clear.
Must go.
Good luck.
John C
Feb 11, 2011 | AEG Lavamat 72640 Front Load Washer
Have Aeg 72630 stopping problem
When it sticks, is the tub empty of water? If so then you may need to change the cold water solonoid just inside machine where fill vaulves are fitted. good luck hope this works
Feb 12, 2010 | AEG Lavamat 72640 Front Load Washer
Aeg lavamat w 1050 electr. rubber problem
dears, thank you for repling of my subject , i solved the problem with replasing other new rubber .
thank you again for your interesting
Mar 23, 2009 | Kenmore 22422 Top Load Washer
Detergent drawer does not empty detergent
hi! remove your powder draw, it should just pull out with a wiggle,give it a good clean in hot water, before you put it back give the draw hola a god clean with a bottle brush and hot water! good luck
Dec 20, 2008 | AEG Lavamat W1050 Front Load Washer
Washing machine AEG 72620 not functioning.
Having worked for AEG for over ten years, the fault is a faulty dispenser unit ( top of soap draw) only fix is to replace the unit ( cost approx £45)
Aug 29, 2007 | AEG Lavamat 72640 Front Load Washer
Washing powder residues left in washing powder compartment.
5 bar is a good pressure. worth while to check the valve filter as suggested. turn off water, remove hoses from machine. look down valve spigot and there is a mesh filter inset. remove with small pliers and clean
Jun 09, 2007 | AEG Lavamat W1050 Front Load Washer
are the holes that spray out the water partially blocked? if so the water will spray out at every angle filling all the tray slots. try popping out the soap tray and cleaning above it with a stiff washing up brush and then reducing the water pressure by turning the tap off a bit.
May 18, 2007 | AEG Lavamat 72640 Front Load Washer
Washing Machines slowly fills with water over a few days
could be leaking inlet valve or if drain is plkumbed in unbder sink, could be filling thro drain pipe when you emptyt sink
Mar 17, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat W1050 Front Load Washer Logo
542 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
