Question about Vtech V.Smile TV Learning System
I require a new power lead that plugs into back of console
HELLO I HAVE MISLAID THE POWER LEAD THAT GOES FROM THE UK PLUG POINT AND INTO BACK OF CONSOLE, I HAVE THE BLUE THOMAS THE TANK VTECH SMILE SYSTEM
  • 8,596 Answers
You can get the adapter directly from VTech, or from Amazon, eBay, eToys, Toys R Us - they all have them.
Posted on Jan 04, 2009
Hello just been given a ps3 you plug it in turn it on and nothing comes up on telle you take the lead out the tele and it says power supply lost plug it back in but still nothing. also it wont turn off on...
u could try resetting ur ps3 by holding down the power button on the front panel for 5seconds/u should hear one beep then a second beep/ps3 should revert back to normal av output.
Oct 14, 2013 | Sony Playstation 3 (PS3) Console
Need a new lead for russell hobbs coffee percolator--CP2 044/495
Hello, Click this link or copy and paste it to your browser http://www.russellhobbs.co.uk/contact_us.html if you scroll down the bottom it provides there phone number as well for customer support for Russel Hobbs in which they can help you to obtain the power wire for your unit. If you have any further questions message me back.
Thank you
Rick
Nov 18, 2011 | Coffee Makers & Espresso Machines
My mate give me a monitor but has no power cable to it looking at the back it shape like a heart
the UK term for it is clover plug, you should be able to pick one up at your computer shop or here
http://www.cables-leads.co.uk/mains-power-lead-240vac-5-amp-uk-plug-to-c5-clover-plug-2m
Apr 17, 2011 | Computers & Internet
Xbox 360 will not power on and the power supply has an orange light
Hi, try this
take out the power lead from back of xbox, turn power lead off at mains and leave unplugged from mains and xbox for at least 5 min,
plug it all back in but make sure you push the power lead into the back of the xbox really hard push it in the try hard to push it in further then plug it into the mains then switch on and press the on button.
if after trying that it still dont work try pressing the open button for the dvd drive as this will switch it on also if their is a problem with the on off button.
if after doing the above you still cant get it on give me a shout back then ill assist you further ok
Dec 12, 2010 | Microsoft Xbox 360 Console
My ps3 console froze and shutoff while playin dantes inferno.disk wont eject
If your PS3 has frozen then you will need to fix ti - this is caused by overheating on the main chips. To do this you can use a good repair guide or you can send it in and they will do it for you.
Jul 31, 2010 | Sony Playstation 3 (PS3) Console
Hi I have got a Lexmark X1190 printer and
you should have a cord for the power supply that goes into the printer from the power supply it plugs into the supply then into the printer, if you don't have it take it back to where you bought it and tell them it's missing. Hope this helps and thanks for using fix-ya.
Jan 26, 2010 | Lexmark X4650 InkJet Printer
MY Power Supply light is blinking orange and xbox 360 want turn on
I hate it when people put "Red ring of Death" for a ORANGE flashing light on the power bar and actually a red ring on the front of the Xbox (which then would mean the red ring of death)!
I just fixed this problem for a friend. They had a contoller charging lead plugged in to the front which had a bad connection in it. Thats all it was so I just unplugged the charging lead and it worked.
So Unplug everything except the power and see if it works 1st, if it does then plug things back in one by one and see when it starts to flash and thats your problem lead there.
Aug 04, 2009 | Microsoft Xbox 360 Elite Console
I plug the xbox 360 in then air comes out the back of the xbox
Hi this is the same and similar fault to the dreaded 3rrod but with a different outcome. the mainboard warps with too much heat and as a result the lead free solder cracks causing this and other similar problems.
we can fix this np for you and get your xbox 360 back to normal if you live in the Uk. we can fix this for £40 including return delivery to your door.
the board needs something called a reflow, the xclamps replaced and heat conducting pads to the memory chips. we also give xbox 360's a good service when we do the repair too.
www.fixmyconsole.co.uk
thnak you
Apr 24, 2009 | Microsoft Xbox 360 Console
Needing instructions to set up
If I remember correctly the master system only has one lead that looks a bit like an antenna connection, one goes into the back of the console and the other goes into the antenna input on the tv.
Then you need to plug the console in to mains outlet turn it on and tune in your tv to pick it up. I normally plug it into the antenna outlet and switch my channel on to the same channel that picks up the vcr, and it works
Nov 18, 2008 | Sega Master System Console
Hi i have mislaid my lead that goes into my printer and the electrical supply can you please help and tell me what lead i need to purchase
If lead you mean power supply, I suggest you go to a computer store as they will most likely have a possible match. Most printer power supply leads/cables have a figure 8 female plug on one end and the plug on the other. The other lead/cable is the USB printer cable which you can buy at the computer store. If your printer is small enough bring it to the store to find a good match. If not I suggest you trace the outline of the female plug on the printer and bring it to the store. Hope this helps.
Jul 25, 2008 | Lexmark Office Equipment & Supplies
Vtech V.Smile TV Learning System Logo
282 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
GI Consulting
relojmesa
Are you a Vtech Toy Expert? Answer questions, earn points and help others
