Question about Lexmark X5150 All-In-One InkJet Printer
When i log on a message........device monitor application has encountered a problem and needs to close.........this is causing problems for me as some things (like messenger doesnt work)
    Genius:
  • 2,035 Answers
Try these steps:
  1. Download the printer driver from the Lexmark website.
  2. Unzip the files but do NOT install the printer using the downloaded driver. Cancel the installation that starts.
  3. Go to the C drive and open the LXK.... folder.
  4. Go to driver and then to win Xp_2k.
  5. Open the View menu and select Details. Details of the file are displayed in columns in the right-side pane. Look for the SETUP INFORMATION file in the Type column.
  6. Open the notepad file in the Name column to its left.
  7. Click Edit, Find and look for the entry that begins:
    LanguageMonitor=
  8. Add a semicolon (;) at the beginning of the entry. NOTE: The semicolon disables the entry.
  9. There are two instances of the word LanguageMonitor in the file. You will need to place a semicolon (;) before itin both places. (Use Edit, Find Next to locate the second instance of the word.)
  10. Click File and select Save. Close the notepad file.
  11. Now look for the CONFIGURATION SETTINGS file in the Type column. Repeat steps 6 through 10 above with this file also.
  12. Go to the Control Panel and select Printers and Faxes.
  13. Open Add Printer. When the Browse option appears, follow the steps for installing the printer using the INF file from the C drive.
  14. DO NOT try to print a test page as a communication error may result. First you need to change the spooler settings. Do the following:
    1. Go to the Control Panel and double-click on the Printers folder.
    2. Right-click on the printer icon and select Properties.
    3. Click the Advanced tab and select Print Processor.
    4. Change the Print Processor to Winprint and the Default Data Type to Raw.
    5. Click Apply and OK.
    6. Attempt to print a document.
Good luck..
Posted on Dec 16, 2008
I HAVE A WHITE SCREEN
White-screens are usually caused by software bugs,poorly written device drivers or might be the malfunctioning hardware.A web based application or a website written in PHP Language will display an empty white page in the browser under certain conditions.If the PHP installation suppresses error messages and encounters a fatal error before any output is produced, PHP will exit and return an HTTP response without content. The error itself may have a wide variety of causes, and can only be determined by reading the server's PHP log (if enabled), or altering the error reporting settings to display the error message.
Jun 22, 2011 | Computers & Internet
On boot, i get the error "Device monitor
Try reinstalling it. It may just be a problem encountered in the installation
Jan 24, 2011 | Lexmark X4975 3-in-1 Wireless Inkjet...
I've tried for several days to connect to Kodak Easy Share and always get the message: has encountered a problem and needs to close.
Either the software is corrupted or is not compatible with your Operating System.There might be problems with your hardware device also (Kodak Device). First of all when the error occurs we have to find why this error occurred. We have to get more details about it. To do so: We have to examine the Error Logs.
  1. Please click on the Start Menu. Type Run in the search box - in Vista - or click on Run - in Windows XP.
  2. Type this and hit enter key. Eventvwr.msc
  3. Go to the Application Category. Check for errors (Red oval with X on it). If there are errors - see the details - for the Application please post it here. You can read the messages and understand which Application that the error is related with. Check the Date and Time values to verify that it is the exact error related to this software.
  4. Then go to the System category and check for errors related to the System if you have connected the Device to the PC. If exists please let us know.
Solution: e easiest solution is to uninstall the software and re install. Download the recent version from here. Note that Apple Quick time is required by the application. Download it from here. Installation Instructions and Operating System Compatibility - Now compatible with windows 7 as well.
Please rate the answer as well if it helps you to solve the problem.
Thanks for contacting Fixya!
Jul 08, 2010 | Computers & Internet
At boot time appears message 'Device Monitor Appliaction (mispell
try this:
1. download combofix and follow his steps (don not agree with recovery console)
link is here : http://www.combofixdownload.com/
notify me if problem is resolved
Jun 28, 2009 | HP Computers & Internet
BlackBerry Calls N' Messaging Problems
are you using an unlocked bold?
it appears you have a corrupt software and you will probably need to reinstall the software.
here is a procedure I found on the Blackberry forum that will possibly help you.
You will need the Blackberry Desktop Software installed on your computer before attempting this.
Problem
The following error is displayed on the BlackBerry device:
net_rim_bb_phone_app killed due to message queue overflow
Cause
This issue may be caused by call logs or BlackBerry device software.
Resolution
To resolve this issue, do the following:
Task 1: Clear Phone Call Logs
  1. In BlackBerry Desktop Manager on the computer, double-click the Back Up and Restore icon.
  2. In the Back Up and Restore window, click Advanced. The BlackBerry device database information will populate the right hand side of the window.
  3. Scroll down through the list and highlight Phone Call Logs, and select Clear. Note: If you are unable to clear Phone Call Logs, delete the Desktop [SYNC] service book on the BlackBerry device. This can be performed on the BlackBerry device by selecting Options >Advanced Options >Service Book and clicking Delete.
  4. Once the Phone Call Logs database has been cleared, disconnect the BlackBerry device from the computer, and then re-connect it to obtain a new Desktop[SYNC] service book.
If this does not resolve the issue, proceed to Task 2.
Task 2
Create a full back up of the BlackBerry device and run Application Loader in the BlackBerry Desktop Manager to erase all data and applications from the BlackBerry device. Refer to KB02318 for these steps. Once Application Loader has completed, perform a syncronization or advanced restore to restore the data to the BlackBerry device. To do this, double-click on either the Synchronize or Backup and Restore icons, and follow the on-screen instructions.
May 30, 2009 | RIM BlackBerry Bold 9000 Smartphone
Lexmark 3550
Uninstall entire lexmark program and reinstall from lexmark web-site.
Jan 22, 2009 | Lexmark X3550 All-In-One Printer
Device monitor application problem
Make sure that the Lexmark Imaging Studio program is running. This was installed when you set up your printer.
If you see the multi-colored icon in your task bar for Lexmark Imaging Studio then try pressing the scan mode button twice. You should be able to scan then.
Sep 28, 2008 | Lexmark X3550 All-In-One Printer
VISTA:The NTVDM CPU has encountered an illegal instruction
The link below is a step-by-step troubleshooter from the Microsoft website. You'll just need to follow all the instructions on the site and you should be able to fix it all by yourself. This seems to be a common error with windows.
Troubleshooting NTVDM and WOW Startup Errors
Sep 10, 2008 | Computers & Internet
you know some of the operating system if there is a corrupted file or dll some of the printers, USB and other devices in-counter this kind of problem you need to fix first your operating system then after that remove your printer driver and re-install again then then try to scan again..... hope this solution help you...
rate this solution please...
Mar 29, 2008 | Office Equipment & Supplies
Sound
You can get drivers for your chipset here http://www.intel.com/support/chipsets/sb/cs-009241.htm This may help solve your problem. A lot of times outdated drivers cause problems like the one you described.
Aug 17, 2007 | Foxconn 865M01-G-6LS, Pentium 4, 865G...
Lexmark X5150 All-In-One InkJet Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
